Username Post: 90 chevy 1500 dies when put in gear        (Topic#284501)
andrew.gonzalez
Reg: 07-23-12
07-23-12 07:11 AM - Post#2251168
i have a 1990 chevy k1500 4wd 350eng
the problem im have is everytime i put it in R or D it stumbles and dies? i replaced the plugs/wire, did oil change, replaced fuel filter, fuel pump, egr vacuum solenoid, idle air control, coolant temp sensor.
it runs great in park and N but if i want to drive it i have to double foot it to keep it going it only does it once warmed up....so any suggestions? im stumped what it could be
thanks for your help
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-23-12 08:44 AM - Post#2251190
    In response to andrew.gonzalez
when you replaced the IAC did you disconnect the battery?
Do you have any codes?
How was the port where the IAC pintle rests? did you clean it out?
It is possible the throttle body could be gummed up.
Unhooking the battery should relearn the idle.
Old School GM fan FOREVER
andrew.gonzalez
Reg: 07-23-12
07-23-12 01:53 PM - Post#2251282
    In response to rockfangd
ive unhooked the battery since then im going to take off the tbi and clean it out completly and replace the vacuum lines ill see what that does
andrew.gonzalez
Reg: 07-23-12
07-23-12 03:20 PM - Post#2251338
update i replaced all the vacuum lines and cleaned the port and still nothing doing same thing
07-23-12 03:52 PM - Post#2251357
Hi Andrew,
Do you have a tach you can connect to tell us what the "in park" idle speed is?
Also, is this a new problem that cropped up after work was done, or the parts you replaced were all because you were trying to solve this problem?
andrew.gonzalez
Reg: 07-23-12
07-23-12 06:02 PM - Post#2251412
    In response to someotherguy
no i dont have a tachthese parts were replaced because of this problem
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
07-23-12 06:11 PM - Post#2251417
I was wondering if you could get a picture of your egr solenoid and where all the hoses are going, very often people connect them wrong and the result is what you see here. Either that or it is bad and did you replace that with your egr?
98 Silverado k1500 4x4 350
andrew.gonzalez
Reg: 07-23-12
07-23-12 06:26 PM - Post#2251426
    In response to 355Cheyenne
i connected them exactly the same as they were when it was working then the problem started
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-23-12 09:20 PM - Post#2251485
it is always good to check to be sure. Also can you manually control the egr servo? maybe the egr is not working properly
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
07-24-12 05:55 AM - Post#2251565
I hate to be a pain but from my experience here it has happened where it was hooked up wrong to begin with but that didn't cause said issue because the egr was bad, once the egr was fixed then the wrong hosing showed itself.
Just double check, the solenoid has 3 ports, one is vacuum from engine, one is switched vacuum to egr and one is vent.
-When egr is off the hose from EGR is diverted to the vent on the solenoid.
-When the EGR is on the hose from EGR is diverted to the engine vacuum.
commonly the vent on the solenoid comes with a foam filter glued to it but not always. I am sure we can turn up a picture if needed.
jham0077
jham0077
Loc: Greenville, Il.
Reg: 11-04-11
07-24-12 09:59 AM - Post#2251662
EGRs act funny. Can you manually move it like rockfangd said? Mine's a stick and when I started out on the clutch, like you would put yours in gear, it would almost die unless I gassed it up. That seems to be the only thing you haven't replaced.
Keep throwing money at it, it'll get better...
95 Tahoe 5.7 w/5 spd
Gone but not forgotten,
87 LWB 4x4 5.0 w/3 spd granny,
84 SWB 4x4 5.7 w/3 spd granny,
93 Full Size Blazer 5.7 w/5 spd,
97 Step-side Vortec w/5 spd.
I like shifting gears.
andrew.gonzalez
Reg: 07-23-12
07-29-12 10:12 AM - Post#2253347
    In response to jham0077
ok took it to a buddy who ran code and it showed the tps when messed up ok fine replaced it and bam nothing is fixed
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
07-29-12 01:11 PM - Post#2253405
make sure the code is cleared and then check again to see if it shows up again, common to find wireharness damage and the sensor isn't the problem but wiring or ground.
Execution time: 0.327 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:23 PM
