tarps (7)
Username Post: rear end        (Topic#284500)
collins toy
Loc: cleveland OH
Reg: 06-06-10
07-23-12 08:11 AM - Post#2251167
So i have a line on a rear end from a 69 camaro for the fleetline. I believe the rear will fit width wise. Does anyone know if the camaro rear will take my stock rims / tires as far as lugs etc.? what would be good gear ratio to run with th350 trans?
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
07-23-12 09:46 AM - Post#2251191
    In response to collins toy
The wheel bolt pattern is the same, 4 3/4" pattern. Butch/56sedandelivery.
Loc: Ellijay, GA
07-23-12 09:54 AM - Post#2251195
I installed a 68 Firebird rear ( same as Camaro ) in a 1950 Chevy I owned many years ago, fit well, but did replace the existing perches with 1 3/4" perches, so as to fit the factory springs better.
I would think a 3:08 rear would work nicely with a turbo tranny, but remember, you will need a $300 adapter to bolt the turbo to the 235.
collins toy
Loc: cleveland OH
Reg: 06-06-10
07-23-12 10:20 AM - Post#2251200
    In response to bobg1951chevy
Guys thanks...im gathering the parts i need now for cheap so i can save the $$$$$ for the big ones lime the adapter and new radiator etc...while im on it i thought i read somewhere if i can get later ( 55 - up) bellhousing the tranny should bolt up without adaptor....but then again i dont read so well!!!
Loc: Ellijay, GA
07-23-12 01:10 PM - Post#2251249
Think what you were reading was in referrence to stick shift. 235 to turbo 350 = adapter.
collins toy
Loc: cleveland OH
Reg: 06-06-10
07-23-12 02:32 PM - Post#2251278
See i told you i dont read so well!!! Thanks
Loc: Ellijay, GA
07-24-12 07:47 AM - Post#2251585
Execution time: 0.061 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:20 AM
