Username Post: hood adjustment        (Topic#284464)
DeeGee
DeeGee
Loc: Oklahoma
Reg: 01-28-01
07-22-12 12:44 PM - Post#2250888
I'm having a heck of a time adjusting the hood on my 60; but I did find this article on hood adjustment (it applies to a 64)and I intend to study it thoroughly, maybe it will tell me how to get the corner of my hood down in the back passenger side about 1/4 inch. Thought I would post it; maybe someone else would have a comment.
http://www.porkbeinspired.com/Resources/Images/292...
A diamond ain't nothing but a piece of coal that stuck with it. Brother Dave Gardner; ca. 1963
Have Wings, Will Travel
Edited by DeeGee on 07-22-12 12:44 PM. Reason for edit: No reason given.
62sedan
62sedan
Loc: North Dallas area
Reg: 08-12-02
07-22-12 01:47 PM - Post#2250912
    In response to DeeGee
Uhhhh..... that website is fine if you're cooking a pork roast, but not so much for hood alignments.
However, loosen the back bolt(s) on the fender side(s) and have someone push up as far as possible on the front of the hood while you tighten the bolts. What this does is rotate the hinge assembly downward at the back, bringing the back edge of the hood down with it. Should do the trick. Don't loosen the front bolts at the fender side(s).
Chuck
Jerry Acheson
Jerry Acheson
Loc: Glenview, IL
Reg: 12-30-00
07-22-12 05:32 PM - Post#2250972
    In response to 62sedan
What problem are you trying to fix? Can you post a picture of what you have?
Links to:
57 Chevy 3100 Pickup
59 Impala Sport Coupe
DeeGee
DeeGee
Loc: Oklahoma
Reg: 01-28-01
07-22-12 06:24 PM - Post#2250995
This works better!
http://www.hotrodders.com/forum/1964-impala-ss- hoo...
DeeGee
DeeGee
Loc: Oklahoma
Reg: 01-28-01
07-22-12 06:33 PM - Post#2250998
    In response to Jerry Acheson
Don't know how to post pics; but maybe I can describe it. On the passenger side, at the cowl, the corner and part of the edge of the hood sticks up about 1/4 inch above the fender. Granted, it may be that the fender is not perfect, but I can push the hood down with my hand and it ALMOST fits.
There are two bolts attaching the hinge to the cowl, and another that attaches to the fender well. It looks as if the hinge is adjusted "down" as far as it will go at the cowl; that is to say, it looks as if the slots in the hinge are bottomed out on the hinge bolts at the cowl. I dinked around with it today and I think I made it worse.
DeeGee
DeeGee
Loc: Oklahoma
Reg: 01-28-01
07-22-12 06:38 PM - Post#2251001
There are two bolts on the cowl side and one on the fender side. I am confused...
Brook2
Brook2
Loc: Christchurch, New Zealand
Reg: 02-10-03
07-23-12 03:00 AM - Post#2251078
There was a similar posting recently. I shimmed the front hinge-to-hood bolt to align the rear of the hood with the cowl. That way when the hood is closed at the front, the hinge will have closed further than previously, which lowers the rear of the hood. Others were keen on rebuilding the hinge, which might be a necessity if the hinge is worn or out of shape.
Cheers
Lindsay
58 Bel Air Sport Coupe Brook2's 58
62sedan
62sedan
Reg: 08-12-02
07-23-12 03:47 AM - Post#2251084
    In response to Brook2
62sedan Said:Uhhhh..... that website is fine if you're cooking a pork roast, but not so much for hood alignments.
Sorry, Dennis. I was thinking about the hinges on my '62.
Chuck
Jerry Acheson
Jerry Acheson
Loc: Glenview, IL
Reg: 12-30-00
07-23-12 04:22 AM - Post#2251089
Brooke is correct. Place shims between the hinge and the hood as he described. That pushes the corner down.
Links to:
DeeGee
DeeGee
Loc: Oklahoma
Reg: 01-28-01
07-23-12 07:22 AM - Post#2251139
Thanks guys. I'll try that.
DthCab60
Loc: SoCal
Reg: 05-03-12
08-03-12 11:34 AM - Post#2255364
I had the exact same issue with the hood on my 60. could push down on it and it would line up. As soon as ya drive it, up it goes. Tried the shim thing. Nada. So! I took the hinge off, hogged out the holes to the cowl so the hinge would move down lower. Boom! done fits perfect, stays put.
DeeGee
DeeGee
Loc: Oklahoma
Reg: 01-28-01
08-04-12 11:57 AM - Post#2255662
    In response to DthCab60
Been too hot to mess with it lately, but I'm saving this thread and will keep that in mind. After working in the yard for a couple hours, and drinking a beer to cool off, I could care less how the hood fits!
Edited by DeeGee on 08-04-12 11:57 AM. Reason for edit: No reason given.
Brook2
Brook2
Reg: 02-10-03
08-06-12 01:56 AM - Post#2256259
If you're going to ask advice on how to drink cold beer on a hot day, this is going to be a long thread...........
Edited by Brook2 on 08-06-12 01:57 AM. Reason for edit: No reason given.
62sedan
62sedan
Reg: 08-12-02
08-06-12 04:20 AM - Post#2256275
Chuck
Jerry Acheson
Jerry Acheson
Loc: Glenview, IL
Reg: 12-30-00
08-06-12 04:23 AM - Post#2256276
That guy needs a funnel.
Links to:
Mister Blue
Loc: Duluth, MN
Reg: 12-04-07
08-06-12 06:29 AM - Post#2256306
All adjustments should be made with the hood latch removed. Line the hood up then install the latch.
If the hood is up in one corner make sure the hinge is not worn out. Two bolts which go into the cowl should be loosened. Then you can move the hood hinge down which will lower the hood..
Execution time: 0.07 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:52 AM
