Username Post: lifters        (Topic#284283)
joeltml
Loc: United States
Reg: 07-18-12
07-18-12 08:27 AM - Post#2249440
on a chevy 216 should i beable to push down on the rockers on the lifter side and lift the rocker off the valve spring?
Edited by joeltml on 07-18-12 08:30 AM. Reason for edit: No reason given.
Jack Crain
Jack Crain
Loc: WIchita Falls, Texas
Reg: 07-24-11
07-18-12 09:37 AM - Post#2249474
    In response to joeltml
you should have a little bit of gap, not sure of the dimitions but you should have a bigger gap on the exhaust valves.
If it is spongey, you may have hydraulic lifters.
1946 Fleetmaster 4-dr Sedan
joeltml
Loc: United States
Reg: 07-18-12
07-18-12 10:46 AM - Post#2249515
    In response to Jack Crain
i think they are hydro.because when i push down on them i get a good 1/4 in gap
joeltml
Loc: United States
Reg: 07-18-12
07-18-12 10:48 AM - Post#2249517
only on some not all of them you think i have some bad lifters
2blu52
Reg: 03-12-02
07-18-12 03:15 PM - Post#2249606
A 216 would not have hydraulic lifters, an early pre 53 235 car engine would. Take a quick glance at the push rod cover on the passenger side. is it short stopping under the spark plugs or does it extend up and around the plugs to the top of the head?
THOMAS JEFFERSON
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
07-18-12 06:40 PM - Post#2249674
    In response to 2blu52
what 2 blue said about the side covers will let you know 100% what you have under the hood.
why do you have this question?
is the engine noisy?
running rough?
depending were the cam is and if its putting tension on the valve train will make a difference on how much "play" you have in your rocker/lifter combo.
to know for sure take the side cover and valve cover off and watch when the cam is over lapping and both valves are closed on teh compression stroke to know for sure what going on.
also if they are hydro lifters and the engine has been shut down for a long time they will "bleed out and get spongy also the more you press on them and fiddle with them with the engine off you will force any remaining oil out and make them spongier.
hope this helps and more info would be great.
Every mother on Earth gave birth to a child.Except my mother,she gave birth to a legend .
ALWAYS TRUST PEOPLE WHO LIKE BIG BUTTS,THEY CANNOT LIE.
Execution time: 0.093 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:34 AM
