Username Post: wheel studs        (Topic#284272)
Lee Thompson
Loc: Bowling Green, Ky.
Reg: 06-10-12
07-18-12 01:24 AM - Post#2249339
62 Impala with 7/16 x 20 factory wheel studs. I need to install longer studs. Are these pressed in? Can I install a lug nut and drive out old studs with a brass hammer? Can these be purchased @ NAPA? Thanks---Lee
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
07-18-12 02:41 AM - Post#2249341
    In response to Lee Thompson
Yes to all your questions.
59 El Camino, 62 Bel Air SC, 62 Bel Air SC(sold in Finland is 2011), 63 SWC Vette (sold)
Member #2194
models916
Loc: Addison, IL
Reg: 05-28-10
07-18-12 07:42 AM - Post#2249412
Skip the brass, use a plain old BFH.
Delray_58
Delray_58
Loc: Scotts Valley, CA
Reg: 03-20-10
07-18-12 08:07 AM - Post#2249431
    In response to models916
What about pressing the new ones on? Is a hammer OK, or does it need to be a press?
'58 Delray 283 3-speed
In the family since new
junky
Reg: 06-27-10
07-18-12 08:26 AM - Post#2249438
    In response to Delray_58
Insert stud, put stud nut on backwards, tighten till the stud pulls all the way through and is seated, and you are done.
Sic_63
Sic_63
Loc: Pennsylvania
Reg: 07-01-12
07-18-12 08:27 AM - Post#2249439
I just used a spacer (old socket) stuck the lug nut on and tightened till it pulled in.
Carmen
1963 Impala 2 Door Hardtop
61Z06
Loc: New Orleans
Reg: 07-13-08
07-18-12 08:48 AM - Post#2249452
    In response to Sic_63
Part number for the studs are 610259 manufactored by dorman. Yes you can get that at NAPA.
Lee Thompson
Reg: 06-10-12
07-18-12 01:07 PM - Post#2249564
    In response to 61Z06
Thanks, you guys are great. --Lee
Delray_58
Delray_58
Reg: 03-20-10
07-18-12 09:48 PM - Post#2249745
Thanks for the tip! Sounds pretty straightforward.
Execution time: 0.23 seconds.   Total Queries: 26   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:22 AM
