tarps (7)
 Page 2 of 2 <12
Username Post: MaddJeff's 327 Motor Build Thread        (Topic#284218)
fuzzyff
Loc: CA
Reg: 06-13-12
07-18-12 08:39 PM - Post#2249721
    In response to nicke
you said your ignition timing is set at 20 degrees initial? (stock setting being about between 4 and 12. (You understand that BTDC means Before Top Dead Center? Could you please clear this problem up for us?
  • nicke Said:
My 327 Build was a .40 over build with a really mild 206/214 duration cam from comp (here) that gets its power off idle, as I wanted good usable power, and in all honesty, 99% of my driving is done under 4000k rpms. I have 9.5-1 compression, and have my timing set at 20 initial, 38 total, coming in at 25-2700rps, and it has really great manners (Vacuum advance is connected to manifold vacuum and is 12 total). I run 93 octane and have no issues at all.
Now that I swapped from a powerglide and 3.07 gear to 200-4r and 3.73 gears, I would have chosen a different cam, but it is still really nice. I also got all the comp stuff for the 461 heads, and did screw in studs and guide plates.
nicke
nicke
Loc: Spokane, Washington
Reg: 01-06-12
07-18-12 09:03 PM - Post#2249727
    In response to fuzzyff
Hey Fuzzy,
Yes, 20 degrees initial. I had it at 12 initial, which is where most guys start, when building a performance. As long as there is no pinging and the car isn't hard to start, with a few exceptions, the more the better. I always use 93 octane, so I am able to get away with this amount of timing.
When you look at all the guys running chevelles at the drag strip, they are running all their small blocks north of 18* initial. Yep, I am aware that BTDC means before top dead center.
Each engine is different, and almost every internal component factors in to what that particular combo likes. I started at 12 and slowly increased, testing out driving, and starting.
20 is where mine is happy.
Does that help?
-Nick
65' Impala SS- Pics
Edited by nicke on 07-18-12 09:04 PM. Reason for edit: No reason given.
66cayne
Reg: 08-06-08
07-19-12 05:48 AM - Post#2249811
I agree. I am running 18 degrees initial on my 327, with vaccuum advance. My combo is a 327 (actually a 331, .030 over) stock 461 heads, flat-top pistons, Comp 268 'Hi energy' cam, Holley 750 3310 vac. secondary., Edlebrock dual plane, 3- speed stick(2.85 first gear)3:08 rear. Starts great, pulls good to 5,500 rpm or so.
ss3964spd
ss3964spd
Loc: Fairfax, Va
Reg: 12-21-00
07-19-12 07:05 AM - Post#2249841
    In response to 66cayne
Nick, 66C, just to be clear for this discussion; is that 20 and 18 initial before connecting the vac advance?
Dan
nicke
nicke
Reg: 01-06-12
07-19-12 08:10 AM - Post#2249854
    In response to ss3964spd
Yep, that is correct. With vacuum hose disconnected and plugged, I have 20 initial, and 38 total coming in at 2500-2700rpm(Most people recommend on shooting for 34-36 total, mine seems to be happy with just a bit more). Then I shut her down, connect the vacuum hose back to full time manifold, and started tuning the carb. Runs like a top.
Hope that helps.
-Nick
65' Impala SS- Pics
Edited by nicke on 07-19-12 08:13 AM. Reason for edit: No reason given.
66cayne
Reg: 08-06-08
07-19-12 06:21 PM - Post#2250060
Yes, 18 degrees before vac. is hooked up.
maddjeff
maddjeff
Loc: Vancouver, WA
Reg: 07-07-12
07-19-12 06:56 PM - Post#2250075
    In response to maddjeff
So, needed a break from work today so I took off early and headed over to the shop to get started on the engine paint. Just got the block prepped and coated today, I'll have to followup with the heads this weekend.
I left the tape on for now as I'm planning on following up with some clear. I may have to do a little sanding as it looks like I had a little lint from the towels I used to clean the block down. I'm digging the cast iron color, it has a metalflake look that is hard to see in the pics. It looked nice in the sunlight!
Jeff
1966 Chevy Caprice 2 Door Hardtop - The Project
1998 Buick Regal GS - The Daily Driver
The 1966 Caprice Project Thread
novice66
novice66
Loc: san antonio,tx
Reg: 05-06-07
07-20-12 12:36 PM - Post#2250288
Dang. Why didn't I think of using That color. It's gonna look good.
<a href="http://www.picturetrail.com/uid9870823" target="_blank"><B& gt;Visit My Trail</B></a>
4dr 57
4dr 57
Loc: The Texas Hill Country
Reg: 11-10-04
07-24-12 03:15 PM - Post#2251744
When the shop redid the valves did they use the tool that not only cuts a new seat but also cleans up the port to about an inch below the seat?
Your going with a roller cam but not using floating pins in the forged pistons?
Back when, we used to take the vibration dampner in when getting the engine balanced. The clutch assembly too, if I recall correctly.
Will adding roller rocker arms require a push rod length check?
Because the heads have been milled might it not be advisable to have the chambers cc'd, so that you know what you have?
I love those 327's, hence my anal questions..can't be too careful when talking high rpm use.
just my $.02
Stanley
Wife: "Don't race the Police car, Stan!"
SS_in_Seattle
SS_in_Seattle
Reg: 05-08-03
07-24-12 05:24 PM - Post#2251809
Jeff,
I really like your primer coat... that motor will look great once you get the Hugger Orange on it
Greg
1965 Impala SS L78
1966 Impala SS Convertible
maddjeff
maddjeff
Loc: Vancouver, WA
Reg: 07-07-12
07-24-12 06:36 PM - Post#2251835
    In response to SS_in_Seattle
  • SS_in_Seattle Said:
Jeff,
Greg
Oops, I knew there was something wrong with that paint... =)
Got the clear on the block and finished up the heads as well today. I should have taken a pic in the sun, it looked really good with the sun shining on it!
Threw an old Holly Contender intake on top to to get a feel for what the finished motor would look like. Once the accessories are on I think it will look really cool in the black engine bay.
And for those of you that bleed Hugger Orange...
Edit: Just realized I have the heads set on backwards. I just threw them on to see how it looked and ran a couple bolts on to hold them in place.
Jeff
maddjeff
maddjeff
Loc: Vancouver, WA
Reg: 07-07-12
07-24-12 06:51 PM - Post#2251840
    In response to 4dr 57
Yes they did.
Was not going to, but are the two linked? Guess I need to look into that more.
Yes, I'll take the balancer and flex plate in when I deliver the crank, rods and pistons.
I believe so. I was planning on ordering new push rods anyway, and I still haven't decided on 1.5 or 1.6 lift yet. This all ties back to the camshaft decision, which I still need to make.
Probably, but they really didn't mill them much. I might do that, but then again this is not going to be a racing motor.
just my $.02
Stanley
Agreed, and all good questions. I need to look into the roller lifter/floating pin thing.
Jeff
50hotrod
50hotrod
Reg: 07-25-11
07-25-12 08:07 AM - Post#2252010
Engine is going to look great!
A couple of things I want to run by you.
I see you are running the heads basically bone stock. I feel you're going to have problems down the line if you run a roller cam under this.
I realize you are not building a race engine but the steeper/quicker ramps of the roller cam is going to take a toll on those rocker studs and springs. And, even a mild roller cam needs more valve lift then these old stock heads can handle.
Usually when you retro fit a roller cam into a gen1 block you install a matched component kit. They also recommend screw in studs.
You still have the option to stay with a flat tappet cam. If you run the correct oil with proper zinc levels you will be fine. ZDDP sells the additive that can be added to any oil also.
maddjeff
maddjeff
Loc: Vancouver, WA
Reg: 07-07-12
07-25-12 09:32 AM - Post#2252028
    In response to 50hotrod
The heads are not quite bone stock, but close. The springs are PSI High Performance and are rated for .55 lift with no problems. I do agree on the screw-in studs, and I'm a little miffed they didn't do that when I picked them up. I'll probably take it back down to get them tapped and prepped and then install them myself with guide plates.
The guy that owns the shop the motor is at is an old family friend I've known all my life. He's a retired ford mechanic and knows his motors, and he's old-school. He used to drill and pin, but I'm generally a lazy guy and would rather have someone else do the hard work, so I'll take them in for the tap work.
As for the roller lifters, it was by no means set in stone. I was just kicking the idea around as I liked the idea of less friction on these motors. To be honest I'll probably go the more traditional route, so no worries there.
Keep up the questions, like I said before I have a lot of catching up to do being out of the hobby for a long time.
Jeff
nicke
nicke
Reg: 01-06-12
07-25-12 09:43 AM - Post#2252030
Good plan Jeff. The screw in studs are cheap insurance...
-Nick
65' Impala SS- Pics
62sedan
62sedan
Loc: North Dallas area
Reg: 08-12-02
07-25-12 11:13 AM - Post#2252053
What?? How can that be.... they're identical. (Or was that a joke? )
Chuck
maddjeff
maddjeff
Loc: Vancouver, WA
Reg: 07-07-12
07-25-12 12:46 PM - Post#2252071
    In response to 62sedan
Sorry, that joke was a touch too subtle... =)
Jeff
62sedan
62sedan
Reg: 08-12-02
07-25-12 02:01 PM - Post#2252100
That's cool. I pondered your statement before my reply, but wondered anyhow.
I'm a big fan of 327's, and am watching your build as you post updates. I like the cast (silver) paint and agree that it will look nice in a black engine compartment.
Maybe not as nice as Chev orange, but nice nonetheless. Here's to you for stepping up to be different.
Chuck
maddjeff
maddjeff
Loc: Vancouver, WA
Reg: 07-07-12
07-25-12 03:13 PM - Post#2252116
Thanks! =) If this was a full-on restoration I wouldn't hesitate for a second in putting on the ol' Hugger Orange, but this is going to be more of a resto-mod.
Jeff
50hotrod
50hotrod
Reg: 07-25-11
07-25-12 05:17 PM - Post#2252162
Did the new valve springs come with collars and split locks?
maddjeff
maddjeff
Loc: Vancouver, WA
Reg: 07-07-12
07-25-12 09:17 PM - Post#2252255
Yes sir!
Jeff
4dr 57
4dr 57
Reg: 11-10-04
07-26-12 05:29 AM - Post#2252308
Jeff -with regard to your interest in rollerized rocker arms; I just ran across an article in the Sept. HOT ROD Magazine on this very subject. Concerning a 327 no less!
I know there is a lot of experience here at CT, however I would also trust this report by Marlan Davis. It related not only to 1.52 and 1.5 roller rockers, he also talks about stock rocker arms along with the pitfalls of such a swap. Well worth the price of admission, and the timing of the article is Great, no?
Hope it helps.
Stanley
maddjeff
maddjeff
Loc: Vancouver, WA
Reg: 07-07-12
07-26-12 07:47 AM - Post#2252348
I'll go pick up the issue today! Figures it was Hot Rod, I get Car Craft & Super Chevy here at the house...
Jeff
SS_in_Seattle
SS_in_Seattle
Reg: 05-08-03
07-26-12 03:11 PM - Post#2252456
Jeff,
Even without a beautiful Hugger Orange paint job, that thing is a vision of beauty. I'm thinking of putting a freshly built big block in my living room as a work of art !
Greg
1965 Impala SS L78
models916
Loc: Addison, IL
Reg: 05-28-10
07-27-12 07:48 AM - Post#2252650
The only advantage of floating pins on the pistons is for frequent disassemble and reassemble. The pin still floats in the piston, just not the rod.
 Page 2 of 2 <12
Execution time: 0.125 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:18 AM
