Username Post: Air Conditioner Filter        (Topic#284038)
GMDave
Loc: Limerick, PA
Reg: 09-16-08
07-13-12 11:01 AM - Post#2247802
When I replaced the compressor on my Suburban, they recommended replacing the filter also. It is about 4-6 inches long and about a half inch diameter cone shaped filter. Where is it supposed to go?
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
07-13-12 11:09 AM - Post#2247809
    In response to GMDave
Sounds like you are describing the orifice, that would be installed on one of the lines on the Condenser. I cannot recall if it was the one from the compressor or to the drier, I am thinking the one to the drier... you unbolt the line and use a needle nose to pull the old one and then install the new one.
98 Silverado k1500 4x4 350
07-13-12 01:32 PM - Post#2247855
When replacing the compressor, you should replace the orifice tube and the accumulator (or "drier"), at minimum. A thorough job would include flushing out the rest of the system (lines, condenser, evaporator core) with solvent meant for A/C systems, to get any debris, old oil, contaminants out of the system.
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
07-13-12 10:20 PM - Post#2248007
    In response to someotherguy
to add Richard, when I did the a/c in my 98 a year ago some one said I should replace the hoses off my pump and I did not listen. I had to replace them this spring as they failed last fall so I personally would add that to the list.
jham0077
Loc: Greenville, Il.
Reg: 11-04-11
07-15-12 12:54 PM - Post#2248438
    In response to 355Cheyenne
Alot of compressor manufacturers won't warranty them without replacement of all the parts Richard said, and flushing the system with a "flush". I fixed my AC two months ago and purchased it all as a "kit". The flush was aggravating because it was just a quart can. I had to funnel it into the lines and blow them out with air.
Keep throwing money at it, it'll get better...
95 Tahoe 5.7 w/5 spd
Gone but not forgotten,
87 LWB 4x4 5.0 w/3 spd granny,
84 SWB 4x4 5.7 w/3 spd granny,
93 Full Size Blazer 5.7 w/5 spd,
97 Step-side Vortec w/5 spd.
I like shifting gears.
Execution time: 0.076 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:34 AM
