tarps (7)
Username Post: New Soleniod installed on 1966 impala ,now not working at all please help        (Topic#284017)
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
07-12-12 08:16 PM - Post#2247613
Thank you in advanced for your help.
Last week I cracked the my soleniod on the relay side. So today i pulled the starter installed new soleniod and now nothing! I have the battery hooked up to the larger post the purple and pink (2 wires) hooked up to the "S" side and a wire from the "R" side to the HEI. I tried taking a screw driver to the 12v post on the soleniod to the "S" post but sparks fly like if it was a sparkler. soleniod wont engage car acts as if i was trying to start it in park.
leon phelps
leon phelps
Loc: Croydon Manor, PA
Reg: 06-04-05
07-13-12 04:14 AM - Post#2247687
    In response to Mja1975
I would put a socket on the crankshaft bolt and make sure it aint locked. may also want to take the plugs out and take a look. they may tell you something.
Metallica Fuel
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
07-13-12 06:09 AM - Post#2247717
    In response to leon phelps
Ok thanks had not thought of that I was also just thinking that maybe I need to check the neutral safety switch
leon phelps
leon phelps
Reg: 06-04-05
07-13-12 06:46 AM - Post#2247726
if you bypassed the electronics (by jumping the solenoid) then the solenoid is not the problem.
we are guessing you could hear it pop out and engage but not turn?
Metallica Fuel
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
07-13-12 09:56 AM - Post#2247781
I wish that was the case the soleniod never engaged Im thinking I may have gotten a bad one
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
07-13-12 07:53 PM - Post#2247966
Thank you for you help I was able to get it the sttarter went bad replaced fired right up!!!!
Thank you!!!
Execution time: 0.117 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:04 PM
