Username Post: Heating a Clifford        (Topic#284005)
53 Hard
Loc: Winters, Ca
Reg: 02-11-09
07-12-12 03:14 PM - Post#2247511
Is there a good way to heat an older non water heated Clifford intake? Or should I just spend the money and buy the newer heated intake? Just curious if there are any adapters or good ideas?
DEEDDUDE
DEEDDUDE
Loc: Beach City, Texas
Reg: 11-06-11
07-13-12 11:03 AM - Post#2247804
    In response to 53 Hard
Pretty easy. I don't have pictures here at work, but I'll try to post some later. I used the bottom of the manifold as a template for the gasket using a ball peen to make it. I used a piece of either 3/4" or 1" plate, cut a little over size of the bottom. Drilled a couple holes in the end and through and off set. The pictures explain this better. I used 1/2" tubing to route to and from the heater inlet and outlet using tee's. The tubing is made buy the same company that makes the brake tubing.
Works great and got rid of the off idle stumble.
DEEDDUDE
DEEDDUDE
Reg: 11-06-11
07-13-12 04:42 PM - Post#2247915
    In response to DEEDDUDE
As promised.
Intake
on the drill press
53 Hard
Loc: Winters, Ca
Reg: 02-11-09
07-13-12 06:30 PM - Post#2247935
Great photos! Thanks! Im a little confused on how the water travels through the plate. Is it just flowing between manifold and plate? How thick is the gasket?
DEEDDUDE
DEEDDUDE
Reg: 11-06-11
07-14-12 03:41 AM - Post#2248024
In the second photo, the holes on top intersect with the holes on the side. I offset the holes to make a longer travel path, not much longer; but working in the space provided. Works great. Not all holes intersect, the two on the left connect and the two on the right connect. My manifold has a same cavity for the hot water to run through.
2blu52
Reg: 03-12-02
07-14-12 05:37 AM - Post#2248046
That is a nice piece of back yard engineering!!
THOMAS JEFFERSON
DEEDDUDE
DEEDDUDE
Reg: 11-06-11
07-14-12 05:52 AM - Post#2248049
Sorry it was real early, that should be a small cavity; as seen in the first photo.
DEEDDUDE
DEEDDUDE
Reg: 11-06-11
07-14-12 05:55 AM - Post#2248051
    In response to 2blu52
Thanks. I looked to buy a heat plate, but none that I found would work. If I had a mill I could have opened up the area within the plate, but it really isn't needed.
53 Hard
Loc: Winters, Ca
Reg: 02-11-09
07-15-12 12:08 PM - Post#2248424
Thanks for the great idea. I just picked one up on ebay. What carb are you running?
DEEDDUDE
DEEDDUDE
Reg: 11-06-11
07-15-12 01:32 PM - Post#2248442
Holley 4412; 500 cfm 2 barrel.
6-bangertim
Loc: El Cajon, Calif.
Reg: 11-30-08
07-18-12 10:38 AM - Post#2249506
Tom Langdon (Stovebolt Engine Co,) has a kit for a stock intake that should also work on a Clifford. You'll need to find a steel "T" to plumb it into the heater hoses, and drill the intake to fit.
A cheap carb to look for would be a Rochester 2-bbl off a 350 V-8, or maybe a used 500-cfm Edelbrock - scored one for 50-bucks from a club buddy!
Good Luck, Tim
Too Poor to Restore...My Nifty 150!
Proud owner of MISS NOVEMBER - 2011 Tri-Five Calender
Loc: Ellijay, GA
07-18-12 08:03 PM - Post#2249706
Why the need for a heated intake in California? I would not go through the trouble.
Execution time: 0.086 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:35 AM
