Sir X Loin
Loc: Naples, Maine
Reg: 04-26-12
07-12-12 10:52 AM - Post#2247423
So about a week ago my car broke down and I thought the rear end was blown. When i would let out the clutch, the resistance was so great that the motor would stall. I couldnt push the car, in nutral either. I had the car twed home on a flat bed a search out rear ends.
About a week went by and since we powder coat at work, I figured Id take the opertunity to do my wheels.since I figured the rear end was locked up, I tried to take off the lugs while in the air. both wheels spun! I tried starting again and letting out the clutch in 1st. the motor still died.
could a broken u joint do this? I really think its up at the trans end. In retrospect I think i head some vibrations the last time I was out coming from that general area.
Im pretty excited as I was going too head out tomorrow and buy a PG rear end for the car, if I dont need to, I dont want to!
Thanks guys!
1957 Chevy Pickup 1998 -2012 *sold
1951 Chevy Styleline Deluxe |
This
Forum is Sponsored by
NWMO 52 Chevy
Loc: Northwest Missouri
Reg: 11-10-10
07-12-12 01:07 PM - Post#2247472
In response to Sir X Loin
Sir X Loin,
Sounds like your tranny may be stuck in two gears. When you put the car up in the air, you can rotate the tires without the pinion gear moving. I suppose your pinion gear or drive shaft could be "siezed" as well, but don't know how common that is.
Chris
Dean50
Loc: Michigan
Reg: 01-02-07
07-12-12 03:47 PM - Post#2247529
My vote is for a loose u-joint. If it came loose (the vibration) it will bind up inside the bell shaped cover. Very easy to check this out. If the flanges on the little lock clips on the u-joint bolts break off, the bolts can back out and your u-joint will separate.
Happened to me last summer.
Thankfully after getting parked, not on the freeway ten minutes before!
Sir X Loin
Loc: Naples, Maine
Reg: 04-26-12
07-12-12 08:05 PM - Post#2247609
In response to Dean50
I really think the tranny is fine. it has shifted great. Hopefully, ill have time to get in and see that U joint this Sat. While the wife works and my kids nap. I practally run to the garage!
Thanks guys.
Just in case, where would I get a U joint? Napa? I havent seen them in Chevs of the 40's..
Dean50
Loc: Michigan
Reg: 01-02-07
07-13-12 01:32 PM - Post#2247856
If you are lucky you can find the little bolt laying inside the ball cover and just put it back in with NEW locking clips. If you need a u-joint check NCA or others.
Sir X Loin
Loc: Naples, Maine
Reg: 04-26-12
07-14-12 11:24 AM - Post#2248141
I have the collar off, I removed the 4 1/2" bolts on the rear, and the 9/16" on the engine side. I cant seem to seperate the Ball. What am I doing wrong? I cant get that apart.
Sir X Loin
Loc: Naples, Maine
Reg: 04-26-12
07-14-12 12:48 PM - Post#2248171
Never mind, I got it. The U joint exploded and sieze in the cup. The inner ball is pretty chewed up, but it should be ok.
I do think I will have to shell out the outragous 190$ at Chevs or the 40's for a new U joint and yokes. The bearing seats are really marred. The retaining bolts were all busted off too.
Dean50
Loc: Michigan
Reg: 01-02-07
07-14-12 02:45 PM - Post#2248191
Wow. Sorry to hear that but at least it's a (sort of) easy fix.
Sir X Loin
Loc: Naples, Maine
Reg: 04-26-12
07-14-12 04:43 PM - Post#2248218
Yeah, I'm going to try and fix the old one. 190 is insane.
Im going to clean them up and see what I can do.
I will need a few gaskets. Chev's has a pack, but I dont want to buy what I dont need. I need the cork ball gasket, The ball retainer gasket and whatever you call the block that I would call a tail shaft houseing. Any idea who would have these on the cheap?
2blu52
Reg: 03-12-02
07-14-12 06:45 PM - Post#2248247
The gasket kit is pretty cheap. Trying to make do with something that is not quite right particularly the ball gasket which is kind of special may end of being more expensive. The PO of my 52 tried to do it with silicone which is almost as bad as nothing at all.
THOMAS JEFFERSON |
Loc: Ellijay, GA
07-15-12 11:45 AM - Post#2248418
In response to 2blu52
Wondering if the u joint took a dump because of incorrect driveshaft inclination .... since the car is so low.
Sir X Loin
Loc: Naples, Maine
Reg: 04-26-12
07-18-12 11:01 AM - Post#2249523
In response to bobg1951chevy
I didnt think of that. It has 4" blocks in the rear on the original sagging springs.
Sir X Loin
Loc: Naples, Maine
Reg: 04-26-12
07-19-12 06:38 AM - Post#2249836
A guy is selling multiple NOS u joint assemblies on ebay for 39.00 with free shipping! What a deal!
cederholm
Loc: Brooklyn NY
Reg: 09-28-10
07-19-12 07:50 AM - Post#2249848
WOW! This is the first time I'm seeing this thread. Glad you found the issue, but sorry it happened in the first place.
Keep us posted.
~ Carl
Carl E. Cederholm
Brooklyn NYC
'53 Deluxe MoreDoor, triPPPle Rochesters, Fenton exhaust, dual Porter mufflers, 3" drop, 12v, and Offenhauser shinny bits! |
chum58
Loc: Sherwood Park Alta.
Reg: 04-19-11
07-19-12 09:14 AM - Post#2249873
Could you post a link please? Thx
Norm
53 Chev Belair HT
62 261
54 pg/diff
Fenton alum twin with Carter/Webbers
(Tom Langdons)
Corvette split exh. manifold. Cherry Bombs /28in
Petronic ignition |
Sir X Loin
Loc: Naples, Maine
Reg: 04-26-12
07-19-12 10:11 AM - Post#2249894
In response to chum58
The guy had 3 for sale last night, and they are all gone! Wow! Thats crazy. There is a used one up for $10 and I had a few people offer them up on the HAMB.
This
