Username Post: ignition?        (Topic#283972)
07-12-12 12:04 AM - Post#2247274
running hard through the gears, runs fine. coasting down after that, the engine dies. this has only happened twice in like six years so troubleshooting could take some time. after a few minutes it starts and runs fine. could it be that little red box?
70 L camino 350 all forged,174 baby blower, g-force 5 spd, road rage suspension. Pray first before all else fails.
55chevy383
55chevy383
Loc: Noble, Ok.
Reg: 12-08-05
07-12-12 09:44 AM - Post#2247389
    In response to bobb
Check your grounds really good, could be a loose ground.
Phil
11.81 @ 113 N/A.
Phil's '55
models916
Loc: Addison, IL
Reg: 05-28-10
07-12-12 10:44 AM - Post#2247419
    In response to bobb
Looks like it won't happen again for 3 years.
07-12-12 08:55 PM - Post#2247629
    In response to models916
more like 6 it happened yesterday.lol.
busterrm
busterrm
Loc: Wichita Falls, Tx
Reg: 08-31-10
07-22-12 11:45 AM - Post#2250872
    In response to bobb
sounds like something is getting hot then cools off, I would thing ground also.
==== BOB ====
If I can't smoke the tires I want more!
1976 Chevy Nova
2007 Chevy 1500 1/2 ton
2005 Yamaha Vstar 1100 midnight custom
models916
Loc: Addison, IL
Reg: 05-28-10
07-23-12 08:32 AM - Post#2251174
    In response to bobb
If it's a points car, I would just change the condenser. Been known to fail when heated.
busterrm
busterrm
Reg: 08-31-10
07-23-12 07:16 PM - Post#2251421
I would have not thought of that, I use electronic ignitions. I do remember that happening on a few cars I had that were 60's year models. My Dad would get crazy when it happened and replace both points and condenser to solve the problem.
==== BOB ====
1976 Chevy Nova
07-23-12 08:04 PM - Post#2251445
    In response to busterrm
well the old dorfs with electronic ignitions did that alot too. im thinking that its not a heat problem cause it runs hard and strong till i let off and coast. maybe its flooding out somehow....
72novaproject
72novaproject
Loc: D/FW Texas
Reg: 02-18-03
07-24-12 05:35 AM - Post#2251532
    In response to bobb
Have you verified that it loses spark when does it? If not it could be a vapor lock.
To each problem exists a solution...now think.
The ZD Nova Page
66cayne
Reg: 08-06-08
07-24-12 05:04 PM - Post#2251799
    In response to bobb
How much rpm are you running? Maybe you are floating the valves and shutting down the engine. That use to happen to me with a big hydralic cam. I would wind it to 6500+ and pump up the lifters sometimes. Engine would shut down and not restart until the lifter drained.
07-24-12 08:33 PM - Post#2251875
    In response to 72novaproject
the first time it happened (years ago) i think i remember it losing spark. the last time it happened, when i checked for spark it was there. its a solid cam, so no pump up. only running about 5500 rpms. its wierd, i coast down and when i get back on it its just mush. assuming there is no spark the engine gets a big shot of raw fuel. i would think thats enough to soak the plugs. i need a test and tune session.
66cayne
Reg: 08-06-08
07-26-12 05:00 AM - Post#2252297
    In response to bobb
Maybe you have a needle/seat hanging open and flooding the engine. Pull, check,re-install and re-adjust float levels.
Willys36
Willys36
Loc: Bakersfield CA
Reg: 07-08-09
08-20-12 09:44 AM - Post#2261296
    In response to bobb
Sounds more like a carburetor problem than ignition.
“We can't solve problems by using the same kind of thinking we used when we created them.”
Albert Einstein
Execution time: 0.093 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:38 AM
