dja
Reg: 06-30-12
07-09-12 02:52 PM - Post#2246234
ok somebody told me that i need to rebuild my eldebrock carb what is the easiest way to rebuild it help below |
\_/
50hotrod
Reg: 07-25-11
07-10-12 09:28 AM - Post#2246546
In response to dja
How did "someone" come to the conclusion that the carb needed to be rebuilt?
dja
Reg: 06-30-12
07-10-12 11:43 AM - Post#2246602
In response to 50hotrod
first im 13 and its my first truck and it s in time and all that but this carb (eldebrock) my frind gave me will not run rite so i took it to the part store and let them look at it and i put the orignal carb that came on it (holly) come to find out is a holly out board motor and yesterday we called to check on it and he said it (elebrock) need to be rebuild he said the people that had it before me must of caught it on fire so it needs to be rebuilt so thats my story and im sticking to it ok
gotta56forme
Loc: West Seattle
Reg: 09-19-03
07-10-12 12:02 PM - Post#2246611
In response to dja
dja,
Welcome to CT and kudos to you wanting to wrench on your own stuff. Do you know which model Edelbrock you have? Some of the more learned here may have model specific info or recommendations that could be helpful to you.
I'm 49, and four years ago I rebuilt my first carb while a learned friend watched and offered helpful information & advice. If you want to rebuild it yourself, do you have any learned friends or family who can offer assistance when you might like? I'm sure there are plenty of guys here who have rebuilt a carb for the first time with nothing more than the carb and a rebuild kit. Brand specific books and online information/articles are available to give you more info. I've found Holley rebuild articles online and Edelbrock ones are probably out there, too. Rebuild kits for almost any of the major brand carbs (Edelbrock included) are typically available. Once you have your model number you can either visit your local autoparts store, or do a web search at Summit, Jegs, Carbs Unlimited, Carb Connection, and more...
There is a professional carb rebuilder who posts here, occasionally. His name escapes me at this particular moment. I think he may sell rebuild kits, as well.
Have fun & good luck,
Scott/Gotta56forme
PS: my first rebuild went pretty smoothly. I just had to pull it off once to readjust the floats.
50hotrod
Reg: 07-25-11
07-10-12 01:20 PM - Post#2246650
In response to gotta56forme
Welcome to CT.
Carbs can be a tricky thing. The key to a successful rebuild is cleanliness. Anyone can install a kit.
I say go for it. This is the best way to learn. Good luck.
dja
Reg: 06-30-12
07-10-12 02:09 PM - Post#2246667
thanx but i live with my grand parents and my g dad rebuilt one a long time ago and its to much to get done by someone else but no im not sure wat model
gotta56forme
Loc: West Seattle
Reg: 09-19-03
07-10-12 02:15 PM - Post#2246670
In response to dja
OK, once you have your carb handy, we should be able to help you find some info on the carb that will help you ID it's model. If the carb was in a fire, one question may be, how bad (hot) was the fire. Are you able to take any photos of the carb and post them here?
Senior Chevytalk Moderator
07-10-12 02:32 PM - Post#2246677
Welcome to the site. Is the carb in a truck? I remember moving your post from the 73-87 truck forum.
Look at the front bottom left corner. It should have a stamped number. IE: 1405, 1406, 1407.
You can find the carb operating manual at http://www.edelbrock.com/automotive_new/misc/t ech_...
The carbs are easy to tune. All you need is a $15 vacuum gauge.
Initial Carb Tuning & Tips from
http://www.nastyz28.com/perftune.html
make sure throttle opens 100%
set idle speed/mixture screws and time engine
adjust idle mixture for highest vacuum reading, reset idle speed
Read this on how to interpret a vacuum gauge: http://www.secondchancegarage.com/public/186.cfm
'96 GMC Jimmy LS |
dja
Reg: 06-30-12
07-10-12 02:34 PM - Post#2246678
may be but wat do u have to look for on the carb to get the model
gotta56forme
Loc: West Seattle
Reg: 09-19-03
07-10-12 02:39 PM - Post#2246680
dja,
Those are just some examples of the edelbrock model numbers. Most manufacturers stamp, cast or emboss a model number onto each of the carbs they build for later ID.
dja
Reg: 06-30-12
07-10-12 02:43 PM - Post#2246683
1405 thats wat it says
dja
Reg: 06-30-12
07-10-12 02:49 PM - Post#2246686
In response to dja
im taking a pic of the carb
dja
Reg: 06-30-12
07-10-12 02:59 PM - Post#2246689
In response to dja
[image]2012-07-10[/image]
gotta56forme
Loc: West Seattle
Reg: 09-19-03
07-10-12 03:04 PM - Post#2246691
In response to dja
While you work on your photo... maybe you can tell us a little more about your truck...
what size motor is in it?
Did you try running the Edelbrock on the truck?
If yes, what sort of problems did you notice?
dja
Reg: 06-30-12
07-10-12 03:11 PM - Post#2246693
In response to dja
[image]C:\Users\aaron\Pic tures\2012-07-10\New folder\[/image]
dja
Reg: 06-30-12
07-10-12 03:13 PM - Post#2246694
305 yes i did it wont let me pass emisons and if u try passing gear it would staRT MESSING UP and poping and try to shut off
dja
Reg: 06-30-12
07-10-12 03:16 PM - Post#2246696
In response to dja
[image]C:\Users\aaron\Pic tures\2012-07-10\new pic[/image]
dja
Reg: 06-30-12
07-10-12 03:17 PM - Post#2246698
In response to dja
how do u post a pic
gotta56forme
Loc: West Seattle
Reg: 09-19-03
07-10-12 03:19 PM - Post#2246700
In response to dja
dja,
I see you are trying to link from your computer, which unfortunately you can't do unless you are a paying member. Here is a link to instructions for posting photos:
dja
Reg: 06-30-12
07-10-12 03:56 PM - Post#2246714
the pics wont work wont work and the web pages is very helpful and its a 84 chevy c10 short bed perl white and a 305 with speed shift tranny 3 speed and a one wheel wonder rear end
gotta56forme
Loc: West Seattle
Reg: 09-19-03
07-10-12 05:06 PM - Post#2246734
In response to dja
dja,
Has your grandpa or grandma been helping you are or have you been doing all the work yourself?
Scott/Gotta56forme
dja
Reg: 06-30-12
07-11-12 05:54 AM - Post#2246899
yes sir
gotta56forme
Loc: West Seattle
Reg: 09-19-03
07-11-12 07:46 AM - Post#2246935
In response to dja
yes, to... all the work yourself?
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
07-11-12 09:25 AM - Post#2246980
In response to dja
An Edelbrock carburetor is not that hard to rebuild, but I would be concerned about what kind of fire it was in. If it was just a carb fire that was quickly extinguished, it is probably of no consequence. But if it was a serious fire, then it is another matter. Email me the photos and I will post them for you: LS-Johanson@wiu.edu.
dja
Reg: 06-30-12
07-11-12 09:56 AM - Post#2246997
In response to rumrumm
no i get help from pops
dja
Reg: 06-30-12
07-11-12 10:05 AM - Post#2247006
i sent the email with the pics
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
07-11-12 01:25 PM - Post#2247088
In response to dja
 Attachment: 003.jpg (179.14 KB) 25 View(s)   Attachment: 010.jpg (174.2 KB) 25 View(s)
Here you go.
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
07-11-12 01:29 PM - Post#2247091
In response to dja
 Attachment: 001.jpg (222.41 KB) 22 View(s)   Attachment: 004.jpg (244.16 KB) 22 View(s)
Two more.
gotta56forme
Loc: West Seattle
Reg: 09-19-03
07-11-12 02:26 PM - Post#2247103
Anybody see anything out of the ordinary? I'm not seeing anything...
(kudos to Lynn for posting the pics)
dja,
you wrote: "305 yes i did it wont let me pass emisons and if u try passing gear it would staRT MESSING UP and poping and try to shut off"
So, you had it mounted on your 305. You took it to emissions testing, and it failed, yes?
When you are driving the truck, when it shifts down, it is popping back through the carb and wants to shut down - so it bucks?
Let me know how much of that is correct and anything else you can think to add...
Scott/Gotta56forme
dja
Reg: 06-30-12
07-11-12 05:00 PM - Post#2247157
thats it but after it pops it tugs and wil hesitate all the same diffrent words same meaning
Edited by dja on 07-11-12 05:12 PM. Reason for edit: No reason given.
