Username Post: Increasing In-gear idle speed        (Topic#283838)
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-09-12 12:14 PM - Post#2246150
Hey guys, as some of you may know, I recently upgraded to a Holley 750 Street HP carb, and couldn't be happier with it.
I've got it set up pretty well, including jetting (had to go down 2 numbers on the primary, that's it). The last thing I want to do now is bump the in-gear idle speed up a bit. Currently, it will fluctuate between 600-700 (big cam), where with my old carb (Holley Street Avenger 670) it would idle in gear at 750, dead on, all the time, and never move more than 50rpm.
The car doesn't lurch with the lower idle like it did before getting the 670 set right, though. It idles smooth, even at 600. The problem is it doesn't generate enough vacuum at 600rpm, and my brakes get pretty stiff. And to a lesser degree of annoyance, it doesn't sound all that good at 600rpm. I'm not interested in installing any vacuum pumps or any of that stuff, because like I said, it would idle great in gear with the old carb.
I currently run 6psi of fuel pressure via electric pump and regulator, and fuel just barely trickles out of the sight hole in neutral at idle. It may be a hair low?
I set the curb idle with a vacuum gauge, it's set to where I get the most vacuum, but my understanding is this isn't ideal for all engines.
Bill - 55 Chevy 210 2 Door Sedan
http://s18.photobucket.com/albums/b129/bluedevil fx...
Tearin' it up:
http://www.youtube.com/watch?v=Xth2oTXLk1Q&a mp;fea...
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-10-12 09:01 AM - Post#2246533
    In response to Mr. Sinister
So any input on the correct way to increase this without screwing up the rest of my settings?
Tearin' it up:
models916
Loc: Addison, IL
Reg: 05-28-10
07-10-12 09:08 AM - Post#2246539
Turn the idle screw clockwise.
50hotrod
50hotrod
Reg: 07-25-11
07-10-12 09:20 AM - Post#2246540
    In response to models916
About all you can do. The cam configuration dictates engine idle vacuum.
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-10-12 10:54 AM - Post#2246589
That has no effect on in-gear idle, it just makes it drop further when I put it in gear. That and oepning the throttle blades more will expose too much of the transfer slot.
Tearin' it up:
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-10-12 10:56 AM - Post#2246590
    In response to 50hotrod
Right, it's same cam I've always had, but with a new carb. If I had it working well with the old carb, I should be able to get it working just as good with the new carb that so far does everything else better but idle in gear.
Tearin' it up:
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-10-12 11:10 AM - Post#2246595
The long and short of it is this: I'm not content to just drop a new carb on the car and call it "good enough", because what separates cars that perform "good enough" and the cars that perform exceptionally is taking the time to tune things the right way. Bolting on a carb and setting the curb speed is not good enough for me, and that's why this little engine performs the way is does. It's not a race car, but I do want it to perform on the street as well as it can within my knowledge and ability.
I tuned everything to work with the old carb as best I could, and now with a new, better performing carb on the engine, I have to start over. I asked questions, I listened to answers, and the difference from "good enough" to where it was is not an accident.
I'm asking what I'm asking because there is more than one single factor that controls the in-gear idle, and I'm looking for the best place to start, now that everything else is set where it needs to be set, including curb idle speed. I don't want to sound like a dick here, but if I didn't know the simple basics, I wouldn't be messing with it in the first place.
Tearin' it up:
gotta56forme
gotta56forme
Loc: West Seattle
Reg: 09-19-03
07-10-12 11:51 AM - Post#2246606
The more learned here will correct me if I'm wrong, but when you went from a 670 to a 750, I'm wondering if the primary bores are a smidge bigger which has caused your idle vac signal to not pull as swiftly as the smaller bore carb. In other words, the smaller bore of the 670 may have had higher flow which sucked in more gas that made for a crisper idle.
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-10-12 12:22 PM - Post#2246618
    In response to gotta56forme
I was thinking along those lines as well. The 670 had the choke removed and one of those stub stacks which are supposed to increase flow velocity, so not only were the bores smaller, but the velocity though them was probably higher as well. The 750 is an HP model, with no choke horn and the smoothed bores, as well.
It's still odd to me why it idles smooth even at 600rpm on the 750, when 600rpm on the 670 would make the car lurch and shake like crazy. It may just be a case of "it is what it is". I can accept that, but I want to know why anyway. I may bring the float level up a tad and maybe try adjusting the mixture screws with it in gear. It's a street car, so idle manners are important, particularly in gear.
Tearin' it up:
gotta56forme
gotta56forme
Loc: West Seattle
Reg: 09-19-03
07-10-12 12:32 PM - Post#2246621
Sorry, Mr Sinister, I guess I had it backwards, I thought the car was idling poorer on the 750 as compared to the 670. Sounds like it's idling better, yes? Maybe it's the difference betweeen a new, untampered-with carb vs. a carb that may have seen a variety of handiwork.
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-10-12 12:40 PM - Post#2246625
Well, depends on what's better. The idle speed was better on the 670. It would idle at 750 in gear and not budge. I can't seem to get the 750 idle speed the same in gear as the 670, but for idling lower, it idles smoother than the 670 did at the same rpm. Where the 670 would lurch and shake at 600-700 rpm, the 750 is pretty smooth. The only issue this causes is a lower vacuum reading in gear, which makes my brakes stiff.
Tearin' it up:
gotta56forme
gotta56forme
Loc: West Seattle
Reg: 09-19-03
07-10-12 12:44 PM - Post#2246629
If it's been asked already, I apologize. Do you know what your idle vac was on the 670 vs. your new 750, both in & out of gear? If there was a measurable drop, maybe you have a vac leak?
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-10-12 12:50 PM - Post#2246638
Actually, I have 13" of vacuum at 950rpm on the 750, where I could only get 11" with the 670.
I've never checked it in gear. I don't suspect a vacuum leak, since it runs like a champ otherwise.
Tearin' it up:
Edited by Mr. Sinister on 07-10-12 12:51 PM. Reason for edit: No reason given.
50hotrod
50hotrod
Reg: 07-25-11
07-10-12 01:02 PM - Post#2246642
Do you have room to advance the timing? That could correct some of the problem.
As far as air screw adjustments, put the car in drive, set the idle speed at 750, now adjust the air screws. If the RPM increases re-adjust the idle speed screw. Sounds like you could use a little more fuel on the idle circuit.
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-10-12 01:18 PM - Post#2246649
Eh, not much if any. I'm at 15* now (vacuum disconnected). It's just on the cusp of making the starter labor. I went with a low vacuum advance can to get my vacuum advance working properly last year. I did have to fab a plate to control vacuum advance at part throttle, and it needed adjusting when I put the new carb on. Probably due to the added vacuum? Either way, not really much room to go up. I did bump it up 1* when I put this carb on to get the in gear idle where it is now. I could try 1* more and see how it goes....
I suspected a lean idle as well. I had the air/fuel screws turned out 3.25 turns on the 670 to get the highest vacuum reading, where it's 2.5 on the 750. So I'm using less fuel at idle with a bigger carb. Kinda counter-intuitive in my mind. Part of why I mentioned peak vacuum reading at idle not always being ideal for all engines in my original post. This HP is more sensitive to changes than the 670 was, this is why I'm being so anal about it.
Tearin' it up:
Edited by Mr. Sinister on 07-10-12 01:19 PM. Reason for edit: No reason given.
07-10-12 01:20 PM - Post#2246652
You are making this too hard. Idle fueling is just a controlled leak. Throttle bore size has nothing to do with the way it idles. Besides there simply isn't that much difference between a 670 and 750.
Likewise on the transfer slot. It's only going to take a tiny part of a turn to increase the in gear idle speed if you really want to increase it.
Just do it, if there's a problem after doing it, then post back.
And once you do it, you may or may not like it.
Usually the problem to solve is the opposite one - idles too fast.
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-10-12 01:29 PM - Post#2246657
    In response to Rick_L
I have a tendency to do that, lol.
I seem to remember trying that to no real avail (the curb speed screw), but maybe not....
Tearin' it up:
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-12-12 05:14 PM - Post#2247550
Finally got a chance to mess with it earlier. Tried the curb speed screw and it would increase the idle in park, but not really anything in gear. I would put it back in neutral and it would go back to idling at 950 where I had it set unless I gave it a good rev. Figured something wasn't right, so I reset the float level so get a little more fuel trickling out, and reset the curb screw. That seems to have done the trick. Idling great in and out of gear now.
This carb is nothing short of amazing with the overall difference it's made. More power, better manners, and better fuel mileage due to less pedal effort at low speed. Throttle response is razor sharp now with the idle sorted, and it just takes a little blip of the throttle to spin the tires. People kept telling me a 750 was too big for this engine (11:1 350, Ported Performer RPM heads, big Comp roller cam). Shows what they know.
Tearin' it up:
50hotrod
50hotrod
Reg: 07-25-11
07-13-12 10:10 AM - Post#2247789
Great Job Sinister! Never settle for good enough.
People told me not to run a Tri-power set up because they never run right. I guess that's why I got it dirt cheap from the guy. He is still shaking his head in wonderment every time I see him. Go figure.
By the way, you have a beautiful car there. I listened to your engine on the youtube clip. Did you build that engine? Sounds perfect to me.
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-14-12 07:49 AM - Post#2248089
Thanks, I did build it myself. This was my first full Chevy build, I did a few ford engines back in my mustang days. Used a 10k mile vortec 350 out of a Chevy HD pickup (so it's a 4 bolt main block). Didn't have to touch the bores, they looked brand new. Reused the entire bottom end, but reassembled it with arp fasteners, and put a set of Keith Black 10.8:1 slugs in it. With the heads, it equals out to 11:1. Never did the math on the DCR, but it's also no race motor, so I'm not terribly concerned with it, since it runs pretty strong. Cam is a Comp XR294HR piece, comp solid pushrods, scorpion 1.5 rockers, and a performer rpm air gap intake. There's a few pics under the hood in my photobucket link. The car runs pretty well for what it is, but some shorter gears and more stall would make it an animal. I do need a new rear though.
Tearin' it up:
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
07-14-12 02:39 PM - Post#2248189
I recently fixed a problem where idle speed would drop from 900 RPM to 500 RPM when I put the trans in Drive. After playing with the idle mixture screws for a long while, I ended up increasing manifold vacuum by 1-2 inches, and idle speed now dropped only 200 RPM in Drive.
You have probably already done that, but I thought I had, too. But if I did, it was 7-8 years ago!
The 350 engine has a fairly mild cam (that now makes 19" at idle), and the Hughes GM11TOW torque convertor is 100-200 RPM looser than stock.
Ah, the beauty of a stick shift in a car with a big cam.
Real Hot Rods have a Clutch!
1969 C-10 pickup: 350, TH350
My car pictures
Edited by MikeB on 07-14-12 02:40 PM. Reason for edit: No reason given.
fuzzyff
Loc: CA
Reg: 06-13-12
07-17-12 12:12 PM - Post#2249128
I really think that the use of Rhoads lifters and/or a vacuum reserve storage tank would totally eliminate your problem, and would be an overall benefit with your setup.
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-18-12 05:19 AM - Post#2249362
    In response to MikeB
One of these days, I will put a manual in it.
Tearin' it up:
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
07-19-12 05:48 PM - Post#2250042
Didn't read all the posts above, but what happens to the timing when you go from Park to Drive? May be a slim chance, but it could be the mechanical advance has just started to kick in at 950 RPM, then totally goes away when you put the trans in drive. So you'd have both the torque converter and spark advance working to drop the idle.
My car pictures
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
07-19-12 09:17 PM - Post#2250124
Never checked the timing in gear, but I seem to have the problem solved. It was a combination of curb speed and float level.
Tearin' it up:
Execution time: 0.149 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:33 PM
