Username Post: This Part of My Holley 4150 Doesn't Look Right        (Topic#283802)
SS_in_Seattle
SS_in_Seattle
Reg: 05-08-03
07-08-12 05:44 PM - Post#2245843
Attachment: 057.jpg (90.4 KB) 14 View(s)
Attachment: 048.jpg (111.94 KB) 13 View(s)
This just doesn't look quite right to me, where the pump over ride sits on the diaphragm lever... what do you guys think?
Greg
1965 Impala SS L78
1966 Impala SS Convertible
bowtieollie
bowtieollie
Reg: 12-06-99
07-08-12 05:47 PM - Post#2245844
    In response to SS_in_Seattle
Hi SS,
You are so correct! The arm appears to be bent.
That bolt head should be riding on top of the lever.
Don't forget .015" clearance at full throttle
Bowtieollie
Chevytalk.com Moderator
TAT_2
"12th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
07-08-12 06:16 PM - Post#2245857
NOTHEN A HAMMER WONT CURE !!!
09 PONTIAC VIBE
08 PONTIAC G6
_-_-_-_-_-_-_-_-_-_-_-_-_ -_-_-
08/01/12 >>> B'CAME VETTE'LESS,
JUST LIKE JEFFREY
NEXT ?
07-08-12 08:21 PM - Post#2245920
    In response to TAT_2
Yep, TAT has the right idea. Just bend it back, then reset the screw for the correct gap.
How in the world did you bend it out like that?
While you had it apart, did you install the anti-blowout modification for the power valve?
http://www.holley.com/125-500.asp
SS_in_Seattle
SS_in_Seattle
Reg: 05-08-03
07-09-12 04:54 PM - Post#2246295
    In response to 427SS65
Tom,
I just put everything back together as it was, and I ordered a couple of generic rebuild kits (The guy I talked to at Holley told me that they don't make kits for the 4150 LIST 3130 any more), and I think I'll order one of those power valve modifiers to put in when I use one of the rebuild kits (after the suregery on my right hand heals).
Thanks for the tips Guys,
Greg
1965 Impala SS L78
07-09-12 08:48 PM - Post#2246400
Just get a ZIP Corvette catalog. All the parts for all Holleys and QJets and others are in there. I believe they sell complete kits.
I like to use the non-stick blue bowl gaskets that I get from Jegs/Summit or any other speed shop you may have around.
What did you do to your hand? Hope it's not serious (or your shift hand).
SS_in_Seattle
SS_in_Seattle
Reg: 05-08-03
07-09-12 10:15 PM - Post#2246420
Thanks Tom,
Everything is running top-notch now, except for the thunk I just heard after leaving the gas station. Thank goodness it was a very strange thing... the radiator drain hose was cut in two and one of the heater hoses jumed out of the fender clamp & was rubbing on the fan. No loss of coolant, no real damage. Sometimes I'm grateful for the oil & temp gauges, oh yeah, and the right hand bus lane that runs through the town I live in where I can limp home.
As for my hand, it's no big deal... I've had the same surgery 3 times on my left hand. It's a condition known as "trigger finger" and the way my Dr. explained it to me, is that the tendons that control your fingers (the in & out of your fingers) runs over a pulley in your palm, and some of us need that pulley widened to accomodate the knot that's grown onto our tendon. The first sign is a click when you grip something or extend your finger, and then after a while you can't extend your finger at all. I could hold a wrench ok, but I couldn't give anyone the finger, lol
Greg
1965 Impala SS L78
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
07-10-12 04:21 PM - Post#2246726
  • SS_in_Seattle Said:
As for my hand, it's no big deal... I've had the same surgery 3 times on my left hand. It's a condition known as "trigger finger" and the way my Dr. explained it to me, is that the tendons that control your fingers (the in & out of your fingers) runs over a pulley in your palm, and some of us need that pulley widened to accomodate the knot that's grown onto our tendon. The first sign is a click when you grip something or extend your finger, and then after a while you can't extend your finger at all. lol
Greg
Is that like Dupuytren's Syndrome?
1955 Chevy Custom
1966 Biscayne
1966 Caprice Drag Car Inwork
1966 Caprice parts car
2004 Silverado
2007 Impala LS
2009 G5
SS_in_Seattle
SS_in_Seattle
Reg: 05-08-03
07-11-12 07:24 PM - Post#2247209
    In response to HAL_396
It's similar in that your finger curls up like you're making a fist, but I think trigger finger is much easier to fix... I looked up Dupuytren's Syndrome online, and the scar from surgery was huge... the incision in my hand is about 3/4" per finger, just below the base of each finger. My surgery was 8 days ago and the pain is minimal & I can almost straighten out my finger now
Greg
1965 Impala SS L78
nicke
nicke
Loc: Spokane, Washington
Reg: 01-06-12
07-11-12 07:49 PM - Post#2247217
Hey Greg!
Glad everything went well with the surgery, and I wish you a speedy recovery!
Also, when you get to turning wrenches on that 66 (or anything else you happen to be working on) in the garage, feel free to give me a call if you ever need a hand with anything! Seriously, I would be happy to help!
-Nick
65' Impala SS- Pics
Edited by nicke on 07-11-12 07:50 PM. Reason for edit: No reason given.
Execution time: 0.149 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:03 PM
