Username Post: Removing motor and trans        (Topic#283768)
Adelaide65SS
Loc: South Australia
Reg: 06-20-11
07-08-12 12:48 AM - Post#2245610
Hi all,
Have purchased an engine crane and I am all ready to lift the big block and auto trans out as my restoration progresses.
I plan to lift using a chain attached to a few exhaust manifold bolts.
My question is can I use the existing bolts or should I get stronger bolts.
If so what is the size and thread?
Andrew
leon phelps
leon phelps
Loc: Croydon Manor, PA
Reg: 06-04-05
07-08-12 02:10 AM - Post#2245613
    In response to Adelaide65SS
why not just run a chain through the exhaust manifold itself and picking up on the exhaust?
Just find some grade 8 bolts that fit through the chain and the heads are enough to not pull through (use washers if needed).
Metallica Fuel
Adelaide65SS
Reg: 06-20-11
07-08-12 06:32 AM - Post#2245646
    In response to leon phelps
Just to clarify, you are indicating that the chain can run under each exhaust manifold front to rear, and then collected above and bolted together to then hook on to crane.
I understand the load is thus spread over 16 bolts via the manifold, which can support it ?
Unfortunately the bolts in the exhaust to manifold connections are rusted so I was trying to avoid cutting the pipes and thought I could lift the engine away leaving the manifolds and pipes 'behind'.
However in playing around with the chain I have found that I cannot move the drivers side manifold far enough away from the head to get a chain and bolt back in as the steering unit restricts the lateral movement of the manifiold.
66cayne
Reg: 08-06-08
07-08-12 07:02 AM - Post#2245656
Your existing manifold bolts are fine. The real trick is getting the auto trans clear of the fire wall as you lift it out. It needs to come out at a fairly steep angle. You should have a helper that can work with the rear of the trans to help it clear
leon phelps
leon phelps
Reg: 06-04-05
07-08-12 08:26 AM - Post#2245675
    In response to 66cayne
just go between any two ports on the manifold and wrap around it then up on both sides. you will be choking it. disconnect the manifold at the donuts.
a 3/8 bolt can hold something like 9k pounds. if you spread it out over 16 bolts and consider the engine/trans to weigh 2k you are well in engineering saftey range. even if the grade 8 bolts were only grade 5 then you would be down to 4k pounds. I think you see my point.
You will need to remove the crossmember for the trans to make it easier.
expect the trans to leak fluid at the yoke due to age.
Metallica Fuel
maddjeff
maddjeff
Loc: Vancouver, WA
Reg: 07-07-12
07-08-12 09:45 AM - Post#2245692
You should pick up an engine lift plate, they are cheap and really make the job a lot easier.
Here's an example of one:
Jegs Engine Lift Plate
They sell them on ebay or most performance shops. Shoot, I think I've even seen them at Autozone and Pepboys before.
Depending on where you attach the chain you can pull the engine out horizontal or at an angle, making it a one-person job. If you have a welder it's pretty easy to fab one yourself as well.
Jeff
1966 Chevy Caprice 2 Door Hardtop - The Project
1998 Buick Regal GS - The Daily Driver
The 1966 Caprice Project Thread
mjc1
mjc1
Loc: Burlington Ontario Canada
Reg: 09-15-04
07-08-12 10:01 AM - Post#2245697
    In response to maddjeff
Use a engine tilting tool. You'll appreciate the adjustability on the fly unlike the plate style.
With this crate motor I used the bolt holes in the heads, but with the earlier motor I'd use the 4 corner intake bolt positions using longer bolts with washers.
Link
1967 Grande Parisienne 4dr ht
My Flickr page, good 65-70 B stuff here...
Impala's under the skin are the Canadian Pontiacs.
Edited by mjc1 on 07-08-12 10:14 AM. Reason for edit: No reason given.
maddjeff
maddjeff
Loc: Vancouver, WA
Reg: 07-07-12
07-08-12 10:47 AM - Post#2245713
    In response to mjc1
Agreed, those are nicer than a plate.
Jeff
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
07-08-12 02:37 PM - Post#2245784
Ditto. I used a leveler when I did mine with a 4 speed.
1955 Chevy Custom
1966 Biscayne
1966 Caprice Drag Car Inwork
1966 Caprice parts car
2004 Silverado
2007 Impala LS
2009 G5
jumbojim
"2nd Year" Platinum Supporting Member
Loc: Melbourne, Australia
Reg: 09-25-11
07-08-12 04:32 PM - Post#2245820
Why not disconnect the transmission before you remove the engine. A bit more work, but much easier to get the engine out. ( Not as heavy, and don't have to worry about the steep angle or oil leaking out trans). Remove trans. later. Jim
Allan In NE
Reg: 12-27-11
07-08-12 04:34 PM - Post#2245821
Get that transmission unhooked first!
Allan
Lifelong GM automatic transmission specialist
Edited by Allan In NE on 07-08-12 04:34 PM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
07-08-12 08:12 PM - Post#2245911
I've found that removing the trans first and then putting a lifting plate on the intake and pulling it out works best for me when working alone. But then, I also do it so I can pull the SB out of my Impala without removing the hood.
slammed1
slammed1
Loc: Ark
Reg: 03-28-12
07-08-12 08:43 PM - Post#2245933
    In response to 65_Impala
Not sure how involved your restoration is but I like to remove the frt core support and sheet metal if Im tearing the car down,sure makes removing and installing the engine/trans combo that way.
Brian M
Adelaide65SS
Reg: 06-20-11
07-09-12 05:28 AM - Post#2246014
    In response to slammed1
All sheet metal is off the front so access is good. Looks like removing the transmission first is the way to go as I can get to all things easily.
Once all bolts 6? are removed and linkages disconnected the block should move easily forward away from the transmission I assume.
To then remove transmission is that simply a matter of supporting it whilst the crossmemmber is removed and then the unit can be lowered.
I cannot undo the rusted bolts at the 'donuts' so I will need to cut the pipes.
Will probably go for headers on rebuild so I guess these first exhaust sections are expendable.
Thanks all for your advice.
Andrew
Australia
jumbojim
Reg: 09-25-11
07-09-12 06:10 AM - Post#2246038
Andrew, its not a bad idea to remove the torque converter bolts before you pull the engine. (Converter stays with the trans). Saves cleaning up a mess of trans. oil everywhere. Make sure converter does not fall off later. Best to tie it on to the transmission. Jim
ss3964spd
ss3964spd
Loc: Fairfax, Va
Reg: 12-21-00
07-09-12 08:03 AM - Post#2246071
    In response to jumbojim
If all the sheet metal is off the front then I'd pull the engine with the trans - just a no brainer to me.
Get a leveler. Small investment, big return. But buy a good one - the cheap ones arn't worth the money.
Dan
slammed1
slammed1
Loc: Ark
Reg: 03-28-12
07-09-12 04:21 PM - Post#2246282
    In response to ss3964spd
Im also thinking since the frt end is off remove it as one piece,since you wont have to get the combo up at too much of an angle to go over the radiator core support it will all slide out real easy.
This is assuming you have the radiator and core support removed.
Mine looked like this 2 days ago then I removed the radiator and core support as I may pull the motor/trans together myself in a few days.
Brian M
65_Impala
Reg: 12-29-02
07-09-12 06:25 PM - Post#2246345
Ya, if the sheetmetal is off then just pull it all together. Put a plug or even tape a bag over the tailshaft to keep oil from leaking out.
jumbojim
Reg: 09-25-11
07-10-12 06:26 AM - Post#2246487
Yes if all the front sheetmetal is off, you should have no trouble pulling the engine and trans. out as a unit. Jim
50hotrod
50hotrod
Reg: 07-25-11
07-11-12 08:16 AM - Post#2246949
Jack the rear of the car up as far as you can get it and place it on jack stands.
Much less of an extreme angle is needed to clear the radiator core support.
Now pull the engine and trans as a unit.
slammed1
slammed1
Loc: Ark
Reg: 03-28-12
07-12-12 07:09 PM - Post#2247587
    In response to 50hotrod
this is a not so good pic of mine with the core support removed,makes it so much easier to remove the eng/trans as a lump this way.
Brian M
leon phelps
leon phelps
Reg: 06-04-05
07-13-12 04:17 AM - Post#2247689
with the radiator support and body off, it was a little simpler.
Metallica Fuel
Execution time: 0.087 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:49 AM
