tarps (7)
Username Post: 94 c1500 tire size        (Topic#283586)
jz512
Loc: Austin TX
Reg: 09-19-11
07-03-12 10:28 PM - Post#2244273
i have 1 flat on my burb..i have a rim and tire i got from a dodge.. will the rim and tire fit...the dodge rim is 16"=bigger tire;..the burb rim is 15"..
just dont want to try and change rims and it wont fit bolt pattern..
Matt
Matt
Loc: SAV
Reg: 09-26-01
07-04-12 03:14 PM - Post#2244524
    In response to jz512
FYI: rim sizes have absolutely nothing to do with the tire size. For example, those are the same size of tires: 315/75r16 and 33x12.50x15. Both are 35" tall tires with different sized rims.
If I was you, I would replace tires on all 4 rims, and have the tire sizes equal. Mismatched tires aren't a good idea. Different used tires have different tread heights which may cause issues to the rear differential.
Execution time: 0.081 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:31 AM
