Username Post: 78 will not start        (Topic#283386)
Chevy78
Reg: 06-29-12
06-29-12 09:05 PM - Post#2242827
Hi need some help. My 78 1/2 ton 350 small block, just stopped running. I replaced the battery, the alt is good, starter is good, and I replaced the ignition switch. The truck will not even turn over. It acts like the battery is still dead. Please help. Just bought the truck.
WagonMan
WagonMan
Loc: SW Kansas
Reg: 10-26-04
07-26-12 09:58 AM - Post#2252382
    In response to Chevy78
Do you have any power to anything else?
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
53 Chevy 3100 (bought '96)
-250 I6/TH350
Chevy78
Reg: 06-29-12
07-29-12 01:35 PM - Post#2253391
    In response to WagonMan
Yes I do. Th dash lights up. But when I crank the motor over, the small negative wire starts to burn.
WagonMan
WagonMan
Loc: SW Kansas
Reg: 10-26-04
07-30-12 06:39 PM - Post#2253960
What small negative wire? If you are talking about the secondary ground from the negative cable at the battery end, make sure the other end of the main negative cable is not corroded and is fastened securely to the engine block.
Charles
-250 I6/TH350
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-02-12 09:32 PM - Post#2255197
exactly bad ground will definately cause problems. Inspect them well. bad ground means lots of resistance
GM fan FOREVER
Execution time: 0.099 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:59 PM
