elmeyer
Loc: Alexandria, TN
Reg: 07-20-11
06-29-12 05:28 PM - Post#2242759
I have a 1964 I6 230 with a 3 speed on the tree. Have a 1992 Camaro T5 I aquired quite a while back. I am going to use my fly wheel. My question is, what clutch kit will work in this case?
Thanks Larry
brokenspoke
Reg: 02-28-08
06-29-12 07:42 PM - Post#2242807
In response to elmeyer
Clutch disk for the transmission, Pressure plate and throw out bering for your truck
brokenspoke
Reg: 02-28-08
06-29-12 07:43 PM - Post#2242809
Your also going to have to move the shifter forward unless your running bucket seats
Do a search on google T-5 tech for lots of info
Edited by brokenspoke on 06-29-12 07:45 PM. Reason for edit: No reason given.
elmeyer
Loc: Alexandria, TN
Reg: 07-20-11
06-29-12 08:32 PM - Post#2242817
In response to brokenspoke
Have put an S-10 tail on it. Will the clutch for my truck work with the input of the T5?
Thanks Larry
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
06-29-12 11:04 PM - Post#2242841
Thanks Larry
"Clutch disk for the transmission, Pressure plate and throw out bering for your truck"
in other words use the clutch disc which is used in orig application for the trans. spline #'s. and buy the pressure plate and t/o that came with your truck.
ron
elmeyer
Loc: Alexandria, TN
Reg: 07-20-11
06-30-12 11:04 AM - Post#2242963
In response to sidworks
Thanks Ron. I appreciate the help, from you & all on this board.
Larry
