Username Post: power window holes in door jam        (Topic#283372)
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
06-29-12 03:58 PM - Post#2242736
A friend is restoring a '57 4dr ht and he is adding factory power windows. He has the harness, switches, looms, motors, etc. but he is unsure about the holes in the doors and door jams. He knows where they go, but does not know the size or shape of the holes. Can anyone post some pictures and dimensions of a factory pw car? thanks
Ken
38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 69 & 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 07 Silverado, 09 BMW 135i convert.
http://www.picturetrail.com/ken58
06-29-12 04:34 PM - Post#2242744
    In response to bowtiefan
Here is the instructions from Ecklers. ..... Link to power window install.
57 2dr HT (restoring)
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
06-29-12 07:57 PM - Post#2242811
    In response to acardon
Can't get the link to open.
Ken
06-29-12 08:42 PM - Post#2242820
Go to Ecklers Classic Chevy web-site. ..... Link to Classic Chevy. Put in part number for the power window looms, 35-78. Click on product instructions.
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
06-29-12 08:58 PM - Post#2242825
All I get is a run time error and it closes the link.
Ken
inline0_0
Loc: Arizona desert
Reg: 03-10-04
06-30-12 05:13 AM - Post#2242867
Don, The link works for me, no problem. Have you had experience using this wire guide/protecter the link shows? Is it really better than the other ways to run the wires?
Doug
Lee T
Reg: 07-05-12
07-13-12 09:19 AM - Post#2247767
    In response to inline0_0
If you have trouble with the reproduction wire conduits, it could be because they are foreign made, like everything else.
[image]http://[/image] [image][/image] [image][/image]
Belair-o
Reg: 03-26-07
07-14-12 05:52 AM - Post#2248050
    In response to Lee T
Wow, what a difference! That explains why when I installed mine (repops), I had to hog out the hole a lot more than the template showed. The difference in the bend of the looms is HUGE! Sheesh!
Doug
62sedan
62sedan
Loc: North Dallas area
Reg: 08-12-02
07-14-12 10:24 AM - Post#2248130
    In response to Belair-o
That's because they've been using Chinese protractors to figure out the angle of the curve, and the degree increments are not marked in the correct locations. Go figure!!!
Chuck
WagonMan
WagonMan
Loc: SW Kansas
Reg: 10-26-04
07-14-12 12:18 PM - Post#2248161
    In response to 62sedan
The Chinese use the metric degree system- 0nly 300 degrees to our 360
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
53 Chevy 3100 (bought '96)
-250 I6/TH350
mikeski
mikeski
Loc: Massachusetts
Reg: 03-26-05
07-14-12 03:20 PM - Post#2248203
    In response to WagonMan
The average Chinese farmer earns the equivalent of $40 US dollars a month. On the bright side, a production worker earns $44 a month! No wonder all our production is going overseas
MikeSki
http://community.webshots.com/user/sroski
inline0_0
Loc: Arizona desert
Reg: 03-10-04
07-14-12 04:09 PM - Post#2248210
    In response to mikeski
Looks like nothing that couldn't be easily fixed with a cutoff wheel in a die grinder making a few pie cuts & then closing the gaps & welding back together. Thank you for the tip, Lee. Wish I had your skills with pictures on the 'puter.
Doug
62sedan
62sedan
Reg: 08-12-02
07-14-12 04:25 PM - Post#2248214
I agree. BUT...... for the prices all these repop parts command, you shouldn't have to do a damned thing to them to get them to fit or work like they are supposed to. Seems like most of the sellers of these parts "play dumb" and tell you what you want to hear about whether or not they are a direct fit. Sorry for the rant, but this kind of crap chaps my a$$ and I don't even own a tri-five!!
Chuck
Lee T
Reg: 07-05-12
07-14-12 06:31 PM - Post#2248240
Since I have originals it was a no brainer for me to just put the repos aside, but after your comments I did a little more comparison and its really an easy fix. The tube part actually has the right bend to it, its just spot welded in at the wrong angle.
I would cut the hole in the A pillar post and just drill the top screw hole in the door, and with the tube loose on one side just keep trimming a little at a time until it fits right. Keep in mind that the location of the bottom screw makes a big difference also because of the curve in it.
Lee T
Reg: 07-05-12
07-14-12 11:47 PM - Post#2248297
One more thing is the directions from Ecklers is to drill the A pillar holes with 1 1/2 inch drill, but the originals were only 1 3/8 inch. The extra size is probably to give those reproduction conduits more room, but I didn't want that opening any bigger than necessary.
Lee T
Reg: 07-05-12
07-15-12 02:59 PM - Post#2248472
inline0_0
Loc: Arizona desert
Reg: 03-10-04
07-15-12 04:23 PM - Post#2248501
Lee, That's a very big help there. Thank You.
Doug
ssffnomad
ssffnomad
Loc: Saratoga Springs N.Y. U....
Reg: 10-19-00
07-16-12 03:08 PM - Post#2248830
Lots of Masking Tape . I used Right Angle Air Drill, then Grinding Burr, then Hand File. Go slow.
" Over the course of history, the kiss of a woman has poisoned a lot of great minds " - Arn Anderson
Execution time: 0.135 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:45 PM
