Username Post: 348 vs. 350 rebuild        (Topic#283364)
Impala58
Impala58
Reg: 06-29-12
06-29-12 02:05 PM - Post#2242697
I have done 350 rebuilds but never a 348. Is there any differences that are unique to the 348. Other than the head shape.
Grey
Loc: Norway
Reg: 08-02-05
06-29-12 04:00 PM - Post#2242737
    In response to Impala58
I have heard horror stories of "machine shops" not beeing aware of the deck angle, assuming it´s at 90deg like other engines. Needless to say it it turned ugly although i suppose these incidents happened a long time ago..
1959 Chevrolet ElCamino
1959 Chevrolet Biscayne
1965 Pontiac Bonneville
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
06-29-12 04:44 PM - Post#2242748
gotta be careful when installing the pistons and not hurt the rings. other than that,just good rebuilding techniques work.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
06-30-12 01:01 AM - Post#2242852
    In response to 62chevy427
Check out 348-409.com for advice as well.
59 El Camino, 62 Bel Air SC, 62 Bel Air SC(sold in Finland is 2011), 63 SWC Vette (sold)
Member #2194
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
06-30-12 04:01 AM - Post#2242862
    In response to DonSSDD
Impala58
Impala58
Reg: 06-29-12
06-30-12 09:03 AM - Post#2242926
Thanks for the info guys.
Jens
Jens
Loc: Emerson IA.
Reg: 04-21-02
06-30-12 10:10 AM - Post#2242950
Don't forget the intake/exhaust push rods are different lengths.
models916
Loc: Addison, IL
Reg: 05-28-10
07-02-12 02:28 PM - Post#2243688
    In response to Jens
If stock, the piston pins are offset left and right. Rear cam bearing is unique and has to be installed by someone that know that. Rear main has two extra seals along the side that lots of people leave out. Early 58 block has a rope rear seal. Oil pump rod is slightly different. Truck timing chain set is retarded from passenger. Oil slinger on front timing gear always gets lost and oil makes its way up the front breather. Just make sure the builder knows the 348 is different than a SBC.
Jens
Jens
Loc: Emerson IA.
Reg: 04-21-02
07-02-12 03:54 PM - Post#2243717
    In response to models916
Good info models. Distributors are also different too.
Execution time: 0.101 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:40 AM
