Username Post: 1964 Chevy II 6 speed trans install        (Topic#283293)
65 pimpala
Loc: Mid Michigan
Reg: 04-08-09
06-28-12 08:18 AM - Post#2242250
Has anyone here installed a six speed gearbox in their Chevy II? If so, I'd like to know how much the floor is going to have to be cut up to fit it. The new transmission is a Richmond with a Long shifter.
Thanks!
06-28-12 07:48 PM - Post#2242427
    In response to 65 pimpala
The Richmond 5 or 6 speed will probably fit the tunnel. A Muncie or T-10 4 speed fits, the Richmond main case is a bit longer but not taller, so near the end of its main case is where there will be a problem if there is one.
I don't think you'll have to do a major cut and weld of whole tunnel like you might with a Tremec 6 speed, which is longer and taller than the Richmond. At worst you'll just need to make a lump in a local area.
65 pimpala
Loc: Mid Michigan
Reg: 04-08-09
06-29-12 08:47 AM - Post#2242594
    In response to Rick_L
Thank you very much for the info. I appreciate it!
Execution time: 0.051 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:48 AM
