Mike_51_Deluxe
Reg: 09-15-10
06-27-12 06:00 AM - Post#2241824
So took her for the first drive in quite awhile. Definitely running better after I made sure the timing was correct. Two issues Id like to get your input on.
First, the valves ticking. I removed the cover and tried to locate the ticking valve/s. While doing this I noticed that the push rods (I think thats what they are) were spinning as they moved up and down, and 2 or 3 were not. Is this normal?
Second, I think something is up with my #3 Cylinder. While running, if I remove the spark plugs there is a noticable change in idle on all plugs but the #3. Its sparking well, and I tested the compression and its 100psi. I then checked the 2nd Cylinder and it was the same, so that ruled that out. Perhaps the valves on cylinder 3 are so out of adjustment that its unable to perform? Thoughts?
Thanks everyone!
| Life's too short, do what makes ya happy and transcend the bull$$$hit |
Edited by Mike_51_Deluxe on 06-27-12 06:02 AM. Reason for edit: No reason given.
This
Forum is Sponsored by
arnieg141
Loc: nj
Reg: 10-06-08
06-27-12 06:49 AM - Post#2241839
In response to Mike_51_Deluxe
MIKE the pudh rods are supost to turn... #3 may be bad plug wire on #3 to check ...take a plug wire off another plug and switch the two wires.. if its bad the other cyl.plug should act like #3 did and #3 will work fine
| GET ER DONE .. AS I GET OLDER I LIKE FAST CARS I CAN STILL DRIVE. AND VERY SLOW WOMEN I CAN CATCH while still able..arnie garrison |
Mike_51_Deluxe
Reg: 09-15-10
06-27-12 07:35 AM - Post#2241863
In response to arnieg141
Thanks for the help Arnie!
I pulled the plug wire off the sparkplug and held it close to the end of the spark plug and there was a clear visible spark from the wire to the plug. Ive also changed the spark plugs around, and it made no difference.
Also, you mentioned that the push rods are supposed to move, what about the ones that arent, is that a problem?
Edited by Mike_51_Deluxe on 06-27-12 07:36 AM. Reason for edit: No reason given.
arnieg141
Loc: nj
Reg: 10-06-08
06-27-12 07:49 AM - Post#2241866
eather to tight. or bad lifter or cam lob is probable bad
Mike_51_Deluxe
Reg: 09-15-10
06-27-12 08:03 AM - Post#2241872
Humm,
Ill have to learn what thost things are and how to check them lol
cederholm
Loc: Brooklyn NY
Reg: 09-28-10
06-27-12 08:04 AM - Post#2241873
Did you adjust your valve as I mentioned in the other thread? All sorts of funky could be going on it your valve aren't adjusted correctly.
...and listen to these guys about your spark plugs.
Carl E. Cederholm
Brooklyn NYC
'53 Deluxe MoreDoor, triPPPle Rochesters, Fenton exhaust, dual Porter mufflers, 3" drop, 12v, and Offenhauser shinny bits! |
arnieg141
Loc: nj
Reg: 10-06-08
06-27-12 08:17 AM - Post#2241878
In response to cederholm
thats true the ones that are not turning may be loose to or to tight try both ways. as far as # 3 that may be just the adjustment also
cederholm
Loc: Brooklyn NY
Reg: 09-28-10
06-27-12 08:29 AM - Post#2241881
Arnieg gives some great tips on adjusting the valves in your other thread - I'd listen to the man.
Carl E. Cederholm
Brooklyn NYC
Mike_51_Deluxe
Reg: 09-15-10
06-27-12 08:42 AM - Post#2241887
Hey,
I havent tried adjusting the valves yet.
I am entirely unfamiliar with this task. Im worried about messing it up and not knowing where they used to be etc.
With no real knowledge here is what Id do.
I would do the adjustment while it was running. (If possible)
Find the noisy valve, and try turning it one way or the other to see if it would remedy the ticking.
Then I would to to my #3 and just guess at which valve needed to go which way wile listening to the idle.
Soooooo, would this be correct?
2blu52
Reg: 03-12-02
06-27-12 09:19 AM - Post#2241901
Regarding th ecompression check. Did you remove all the spark plugs, block the throttle pedal open and then check compression? If you did not then the compression check would not be accurate.
THOMAS JEFFERSON |
arnieg141
Loc: nj
Reg: 10-06-08
06-27-12 09:29 AM - Post#2241905
Hey,
mike you can do it your way .sent idle as low as you can get on carb with out staleing.i would do the push rod ones not rotateing/spinning first and get them spinning.
Mike_51_Deluxe
Reg: 09-15-10
06-27-12 09:53 AM - Post#2241919
I wouldnt say that is "my way" I was just explaining that having no idea what I was doing, that is what I would do. If that works then sweet, Im smarter than I thought lol.
On a side note, I did notice the ones NOT spinning were wayyyy more hot than the ones that were. So good call, Ill start there.
PS this is a really well written link on valve adjusting
http://www.speedprint.com/deves50/valveadjust.php
Edited by Mike_51_Deluxe on 06-27-12 10:04 AM. Reason for edit: No reason given.
arnieg141
Loc: nj
Reg: 10-06-08
06-27-12 10:13 AM - Post#2241932
that tight one is the first to do it should be no hotter than any other all should spinner freely.that is a great link mike. and would be the way to go but can be very trouble some for the beginer but once learned works well but always need to twick even with that wides up with .the ear!!! to get right
cederholm
Loc: Brooklyn NY
Reg: 09-28-10
06-27-12 10:24 AM - Post#2241936
Arnieg, correct me if I'm wrong, but isn't it better that they are a little loose and noise then overly tight? ...just something to think about.
Carl E. Cederholm
Brooklyn NYC
Mike_51_Deluxe
Reg: 09-15-10
06-27-12 10:25 AM - Post#2241937
Right on Arnie,
Thanks for all the help. So for now Ill go home and see if I cant get those tight ones to spin freely, as well as find the loud ticking one/s and do some minor adjustments.
arnieg141
Loc: nj
Reg: 10-06-08
06-27-12 10:43 AM - Post#2241942
carl true you should never have a tight one thats how valves get burnt and push rods bent. some cars esp. with solid lifters you may not get out all clicking from them but some you can .you will never get a solid lifter car as quite as a hydrolic lifter car but can get it close
Mike_51_Deluxe
Reg: 09-15-10
06-27-12 12:37 PM - Post#2241977
Ive read the valves are supposed to be a little noisy, but not like this. Its annoying while driving especially when you accelerate.
arnieg141
Loc: nj
Reg: 10-06-08
06-27-12 01:07 PM - Post#2241986
you are so right mike solid lifter alwas have a littie click but with motor raced up or driveing should be gone.it takes awhile to play around adjusting them .but you'll be ok
Mike_51_Deluxe
Reg: 09-15-10
06-27-12 01:17 PM - Post#2241987
Oh yeah, Im not worried about it. STOKED that this thing is driving again. 100% more motivation to keep working away on her. LOTS to do still. All exterior trim, basically all the electrical will need to be done, radio, interior trim etc. But at least shes running.
Mike_51_Deluxe
Reg: 09-15-10
06-27-12 01:32 PM - Post#2241995
Last question, if the lifter is not rotating, should I turn it to the left or right? Im assuming lefty loosy righty tighty, but Ive been wrong before.
Thanks guys
arnieg141
Loc: nj
Reg: 10-06-08
06-27-12 02:09 PM - Post#2242011
you just loosen nut just enough to turn the adjuster screw . . right tight left loose
Loc: Ellijay, GA
06-27-12 04:56 PM - Post#2242055
100% correct!
Loc: Ellijay, GA
06-27-12 05:00 PM - Post#2242057
Can you be certain the noise you hear on acceleration is NOT the timing being too far advanced, as opposed to a valve clatter noise ?????
Loc: Ellijay, GA
06-27-12 05:03 PM - Post#2242058
Thanks guys
You will not see any lifter rotating, but you will see a pushrod turning. You NEVER want to get the adjustment TOO TIGHT, for you will do damage then to the valve.
Dean50
Loc: Michigan
Reg: 01-02-07
06-27-12 05:31 PM - Post#2242068
In response to bobg1951chevy
Mike, only tighten 1/4 turn at a time. When you get them all where you want them, retard your timing a couple of marks on the octane selector, per what Bob G stated. The noise on acceleration could be from the timing being too advanced.
53belair
Loc: Ellerslie, Georgia
Reg: 03-25-07
06-27-12 06:40 PM - Post#2242091
In response to Dean50
I wondered the same thing. When these engines were made (or shortly thereafter) premium "ethyl" was 100 octane (103 for Standard "white" gas) and regular was higher than today's mid level/as high as today's premium. Preignition ping from the lower octane is often refered to as "the valves rattling" by drivers.
Loc: Ellijay, GA
06-27-12 11:40 PM - Post#2242162
In response to 53belair
Read this partial article on the history of gasoline.
The History of Gasoline Octane
As the high compression engine era was gaining steam in Detroit during the early to mid 1950s, the need for higher octane gasolines was becoming more and more apparent. When automobile production resumed in 1946 following World War II, gasoline octanes in the United States averaged at 79 for regular and 85 for premium and those numbers climbed year after year until 1954, when premium gasolines were rated as high as 94 octane and regular at 86. Oil companies were promoting their gasolines, especially their premium grades, with claims that their fuels increased power and gas mileage while cleaning out the carburetor and other engine parts to wash away accumulated carbon and other deposits while regular usage prevented the future buildup of such. Among the additives widely promoted by leading oil companies were Texaco Sky Chief with Petrox, Super Shell with TCP, Mobilgas Special with a Double Compound ingredient and Sinclair's Power-X featuring a nickel additive.
arnieg141
Loc: nj
Reg: 10-06-08
06-28-12 04:59 AM - Post#2242184
oh ya bob.
Mike_51_Deluxe
Reg: 09-15-10
06-28-12 06:09 AM - Post#2242200
When I was talking about the noise when accelerating, I meant the ticking. There is one pretty loud ticking valve and when Id accelerate it would be pretty noticable, where it was all you could really hear in the cab.
I did some work on it yesterday, and some of the push rods have been replaced witrh much beefier looking ones. One of these is also the "ticker" I adjusted it either way til it started to quiet up.
The car is running really well now. Sounds nice and happy. Also, while adjusting the valves I notived oil is making its way up there just fine which is a good feeling. Took it for a drive and felt very confident in its mechanical ability.
Time to start a new thread on the next journey.
When I bought it
Doing some body work/rust removal
How she's lookin now
cederholm
Loc: Brooklyn NY
Reg: 09-28-10
06-28-12 06:20 AM - Post#2242204
When I bought it
Great work Mike!!
...and great help from the board!!! ...you guys really know your stuff and us "new to old Chevy" guys are very lucky to have you around.
~ Carl
Carl E. Cederholm
Brooklyn NYC
This
