Username Post: STILL FOULED PLUGS ON MY 4.3        (Topic#283181)
chevylover
Reg: 05-25-04
06-25-12 10:52 PM - Post#2241387
HI, I AM STILL HAVING A PROBLEM WITH THE LAST TWO PLUGS ONE ON EACH SIDE FOULING OUT. AND STARTING TI MISS. HAVW ANY OTHER IDEAS TO SOLVE MY TROUBLE. I HAVR POSTED THIS BEFORE. TJANKS, WALT
sgian
sgian
Loc: MO
Reg: 12-25-03
06-26-12 02:57 AM - Post#2241399
    In response to chevylover
Can you post a pic of the fouled plugs? I suspect valve stem seals, because the back ones are often the first to go in the sbc's that I'm used to. Here's a good reference on fouled plugs. spark plug reference
So I would suspect the plugs to be black and kind of wet or sticky. Am I right?
04 Silverado Z71, 10 Cobalt
chevylover
Reg: 05-25-04
06-28-12 01:10 PM - Post#2242311
    In response to sgian
HI, I JUST CHANGED THE TWO FOULED PLUGS. THE NEXT TIME I CHANGE THEM I WILL POST. THE OTHER PLUGS IN THE ENGINE ARE JUST FINE ONLY THE LAST TWO ARE BAD. THANKS FOR YOUR CONCERN. WALT
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
06-28-12 10:18 PM - Post#2242457
Maybe I am not seeing it but what year?
98 Silverado k1500 4x4 350
chevylover
Reg: 05-25-04
06-29-12 08:34 PM - Post#2242818
    In response to 355Cheyenne
HI, IT'S A 1993. SOMEONE SAID THE O2 SENSOR MIGHT NOT GET HOT ENOUHH AND TELL THE COMPUTER IT NEEDS MORE FUEL BECAUSE IT RUNS ALITTLE RICH ON THE LAST TWO PLUGS., ????? THANKS, WALT
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
07-02-12 12:04 PM - Post#2243652
what brand plug and model? Are they all the same?
chevylover
Reg: 05-25-04
07-02-12 08:45 PM - Post#2243818
CHAMPION 15 OR 19 THANKS, WALT
aggiecowgirl12
Reg: 06-30-12
07-03-12 07:24 AM - Post#2243953
Hmm.... sounds like a fuel issue, mixed with maybe your valve seats? Does it puff black smoke when running? Could mean your rings are bad. Have you done any upgrades on the fuel system, like the new delphi spider injector?
97 Chevy K2500 3/4 ton extended cab, long bed, Rebuilt NV4500 with the 5th gear mod, centerforce clutch, Delphi spider injector upgrade, 4 inch lift on 33x10.5 all terrains...
"You may all go to hell, and I will go to Texas." - Davey Crockett
Execution time: 0.108 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:14 PM
