Username Post: Remove oil pan 1970 C10 with 4 Speed        (Topic#283084)
clj866
Loc: Kaufman, TX
Reg: 06-24-12
06-24-12 06:23 AM - Post#2240700
Need to remove oil pan to change out oil pump. Can I loosen motor mounts and raise slightly to get clearance? Do I have to take out tranny? I am a novice with this truck so any help would be greatly appreciated.
bobschevytrucks.com
davidchristopher
davidchristopher
Loc: Saint George, Ontario, Ca...
Reg: 08-02-09
06-24-12 12:04 PM - Post#2240789
    In response to clj866
if it's a small block you're talking about, then yes- you should be able to loosen the mounts and raise - with a hoist - the motor if you need clearance. The transmission doesn't touch the oilpan.
I must urge you to be safe when doing so. Don't 'over loosen' the mounts. Do only what's necessary to clear the pan / crossmember.
I'd also suggest undoing the bolts - if you can - before you raise the motor- to minimize the amount of time you spend under a 575 lb hunk of metal hanging precariously from a chain.
Once the pan is cleared, lower the motor again. Do any scraping/gasket cleaning on the block with the motor secured.
Re-raise it when you're ready to re-install the pan- but again - do the minimum amount necessary while the motor is in the air.
Once the pan is in place, lower the block again and torque to spec.
1951 Chevrolet Styleline Special. (350 4 Muncie '55 Driveshaft CE crossmember Heidts Mustang II front suspension, 3:10 Posi)
The '51 Chevy Blog
clj866
Loc: Kaufman, TX
Reg: 06-24-12
06-24-12 12:51 PM - Post#2240802
    In response to davidchristopher
Thanks for that info, i will be very careful when trying this, now i just need a hoist too hold that much weight so off too shop for a hoist.
JimKshortstep4x4
Chevytalk Moderator & "9th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
06-24-12 03:16 PM - Post#2240849
Welcome to Chevy Talk from West Michigan!
Let us know how your project turns out.
Member 65-66 Full Size Chevrolet Club
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
71 Short bed stepside 4x4, 350/350
Current project, 72 GMC Shortbed, stepside, 427
bobschevytrucks.com
Execution time: 0.111 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:20 AM
