tarps (7)
Username Post: I'm Jambing!        (Topic#283083)
Ol Dirty T
Loc: Michigan
Reg: 01-10-09
06-24-12 06:10 AM - Post#2240695
I'm finally adding color! I never thought I'd be at this stage. I've been using Omni Products all along an at $689 a gallon for just the PPG DBC alone, I wasn't going to change now. I got the sealer, a gallon and a quart of base, and my clear for under $600. The clear is actually Nexa brand which is PPG's European brand. I've thing everything came out great. Here's a few pics
Kabous66
Reg: 04-18-11
06-24-12 11:11 AM - Post#2240776
    In response to Ol Dirty T
Looking fantastic!!!
I only wish I'd been smart enough to remove my door latches before painting... Just didn't know better...
I've been thinking about trying to tape them off and then use a dremel to try to sand off the paint... Something tells me this wouldn't be a bright idea, and that I'd end up causing more problems....lol...
My ignorance on my first build...
Kabous66
Reg: 04-18-11
06-24-12 11:12 AM - Post#2240777
    In response to Kabous66
Forgive me, but I can't recall if you're going with Madeira Maroon or Regal Red? It looks a lot like mine...
slammed1
slammed1
Loc: Ark
Reg: 03-28-12
06-24-12 11:48 AM - Post#2240783
I cant wait to have mine at this stage to where you have yours. looks like your doing the job just the way it should be done.Very nice.
Brian M
Coalflyer
Reg: 01-19-12
06-24-12 02:26 PM - Post#2240831
    In response to slammed1
Very well done!
Fossil_Fuel
Fossil_Fuel
Loc: Minnesota
Reg: 09-11-07
06-24-12 04:05 PM - Post#2240879
Steve,
If you have not yet installed your door panels then removing the door latches is fairly simple. just a couple rod clips and the 3 attachement screws. Once removed you can clean off the paint and remove the old grease. It will work way better with new grease. Be sure to use a impact driver to remove the screws if they have been there for a while.
1964 Impala SS 327/300 since '76
1967 Impala SS 327 Triple Black Hardtop in the works
http://craigaacars.shutterfly.com/pictures
Execution time: 0.097 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:59 AM
