phillipm
Reg: 02-11-12
06-24-12 05:59 AM - Post#2240692
I've replaced the shocks front & back. Front end is too high. 151/2" from bottom of bumper to ground.
What do I need to do to lower?
phil
This
Forum is Sponsored by
06-24-12 06:39 AM - Post#2240711
In response to phillipm
Shocks will not change ride height unless they are air or lift shocks. Springs and tire size are the only thing that affects body height. Make sure the springs are properly seated in the pockets. .... Link to springs.
57 2dr HT (restoring)
Bad270
Loc: Weeki Wachee, Fl. 34607
Reg: 08-04-07
06-24-12 07:05 AM - Post#2240713
Heavy duty springs will also raise the front end about an inch-ask me how I know.
06-24-12 08:22 AM - Post#2240732
In response to acardon
Slight correction, shock can change ride height if they are the wrong shocks. If they are fully compressed and too tall, they can change the ride height. Very unlikely, however. It would be unusual for the spring to come out of the pocket just from raising the car up to change the shocks, but make sure they are seated in the pockets properly. Worse comes to worse, take the shocks back off and let the car down and see what the ride height is then.
1957 Nomad sport wagon |
phillipm
Reg: 02-11-12
06-24-12 03:52 PM - Post#2240869
In response to wagonman100
Is there something that gives me the dim. of ground to bumper for the front? I know the back is low for it had load levelers on it when I got it.
06-24-12 04:51 PM - Post#2240892
Bumper to ground measurement will vary with tire size and bumper adjustment. There is a procedure in the shop manual to check the stock ride height. .... Link to ride height.
This
