Username Post: front fender        (Topic#283079)
sanmanjim
Reg: 06-02-12
06-24-12 03:53 AM - Post#2240669
Description:
I have a 1972 stingray...after having the engine taken out and re-done I recieved the car back with a problem with spacing on the front end...when looking from the front the whole front end is very slighlty tilted up on the passenger side and down on the drivrs side...the hood is aligned correct but the spacing between the hood and passenger side fender is very tight and on the drivers side there is a larger gap...is there anyway to re-adjust the front end to correct the spacing between the hood and fenders so they are the same width ...any suggestions?? or fixes ?? Like I said...the hood is aligned correct...it's perfectly matched to the grill in front of the wiper door
old_gto
Needs to Get Out More Member
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
06-24-12 04:25 AM - Post#2240674
    In response to sanmanjim
Sounds like they didn`t align the hood right when they put it back on. If you loosen the hood hinge bolts, you should be able to move it left or right, forward or back, and get the gaps evened out.
As for the height, was there any shims between the hood hinges and body that are not there now?
The only thing I`m sure of, is that I`m not sure of anything.
71 Corvette, 97 burb, 66 GTO, 69 Grand Prix, 65 Mustang, 65 C-10 Fleetside, 67 Mustang
Too many toys, not enough play time!
YeniPenny
YeniPenny
Loc: Biloxi, Ms
Reg: 11-26-01
06-24-12 12:15 PM - Post#2240796
There is a very slight amount of adjustment on the front clip at the "wishbone" mounting point.
Was it already out of adjustment? Normal engine work shouldn't have affected the front clip alignment in any way...unless someone did something really stupid.
old_gto
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
06-24-12 01:23 PM - Post#2240810
    In response to YeniPenny
EXACTLY! But the hood and radiator would need to be removed to pull the engine. So my bet is they just dropped the hood back on, and didn`t bother to properly adjust it.
TAT_2
"12th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
06-24-12 03:34 PM - Post#2240858
    In response to old_gto
SOME IDIOTS DONT RAISE THE HOOD UP FAR ENUFF TO 2 RELEASE THE LOCK,THAY JUST FORCE THE HOOD DOWN !!! IF ITS OUT OF ALIGNMENT, 1 LOCK ON EITHER SIDE MIGHT NOT CATCH.
09 PONTIAC VIBE
08 PONTIAC G6
_-_-_-_-_-_-_-_-_-_-_-_-_ -_-_-
08/01/12 >>> B'CAME VETTE'LESS,
JUST LIKE JEFFREY
NEXT ?
DEI8FAN
DEI8FAN
Loc: Western, N. Carolina
Reg: 02-01-05
06-25-12 04:06 AM - Post#2241042
Is a 72 that much different than a 81? I had my engine out to change freeze plugs and didn't have to take the hood off.
1959 El Camino
1970 El Camino
1981 Corvette
2004 Z71
2005 Monte Carlo
davidchristopher
davidchristopher
Loc: Saint George, Ontario, Ca...
Reg: 08-02-09
07-04-12 07:34 PM - Post#2244602
Don't mean to hijack, but does anyone know HOW MUCH you can adjust it? I have a '73 where the door clips the fender on the passenger side, at the bottom. I've not gotten to this project yet, but this has me thinking...
Mind you, it's probably the body mounts or some other rust issue, but still, ever lead is worth checking out.
1951 Chevrolet Styleline Special. (350 4 Muncie '55 Driveshaft CE crossmember Heidts Mustang II front suspension, 3:10 Posi)
The '51 Chevy Blog
TAT_2
TAT_2
Reg: 10-29-00
07-05-12 05:30 AM - Post#2244657
    In response to davidchristopher
CHECK THE PINS & BUSHNGS IN THE HINGES,I REBUILT BOTH SIDES ON THE 78
09 PONTIAC VIBE
08 PONTIAC G6
JUST LIKE JEFFREY
NEXT ?
old_gto
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
07-05-12 02:13 PM - Post#2244801
    In response to TAT_2
Yup, is it the door sagging, or the body? The only adjustment I know of in the front clip is at the very fr4ont, where the frame extentions come off the front frame. They bolt to the crossmember, and the radiator support bolts to that. The front fenders are supported by the radiator support.
wagonmaster
wagonmaster
Loc: Loganville, Ga.
Reg: 04-28-00
07-05-12 04:40 PM - Post#2244851
Jim,
How's that '71 coming along??? Progress pics???
Hey T @!
Joe
old_gto
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
07-06-12 03:32 PM - Post#2245234
    In response to wagonmaster
Doing good Joe! I just posted a new thread.
wagonmaster
wagonmaster
Reg: 04-28-00
07-06-12 03:43 PM - Post#2245240
Hey T @!
Joe
Execution time: 0.125 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:06 PM
