oldblue51
Loc: Littleton,Colorado
Reg: 08-19-10
06-23-12 10:31 PM - Post#2240659
So I finally dumped the money for an Ididit column , now need to wire it and im friggin lost. Have a 52 styline deluxe, v8 . Theres this plug hanging out of the column and i found the schematic for it. So do i splice this in or is there a harness that i need to buy? I will also mention that im converting to 12 volt too.ive read all about that and seems pretty straight forward. Any help on the column would be appreciated. Thanks
'48 chevy 5 window pickup
'52 5 window pickup
'52 chevy panel
'52 styleline deluxe
'53 suburban
'41 business coupe
'72 C10
'96 3/4t burb
'02 Burb
'70 VW bug
Yep, its a disease......
This
Forum is Sponsored by
50sChevys
Loc: Central Texas
Reg: 03-23-02
06-23-12 11:17 PM - Post#2240661
In response to oldblue51
You can get a wiring connector plug kit for the Ididit column from several places. Jegs, Summit, American Autowire, etc. I got mine from YNZ which did the new harness for my '50. Call them first and tell them your specifics and they will help you. You will have to make a change or two, but it's easy and you can do it if you can read a simple schematic. The plug fits right up.
http://www.ynzyesterdaysparts.com/
50hotrod
Reg: 07-25-11
06-24-12 08:24 AM - Post#2240733
In response to 50sChevys
If your converting to 12 volts are you using an aftermarket wiring harness?
I know the EZ wiring harness comes with the column plugs and the ends are already attached the the column wires in the harness.
oldblue51
Reg: 08-19-10
06-25-12 05:13 AM - Post#2241056
In response to 50hotrod
Nope, using stock harness
'52 5 window pickup
'52 chevy panel
'53 suburban
'41 business coupe
'72 C10
'96 3/4t burb
'02 Burb
'70 VW bug
This
