Devin
Reg: 06-16-12
06-23-12 03:36 PM - Post#2240560
Hi all -
I have a Holley 950 Commander MPFI setup that I am trying to figure out the idle on. I have searched through quite a few threads here and couldn't find what I was looking for.
I have two issues:
1. Upon startup, the vehicle surges to a high idle, then settles down to the desired idle. I have the latest firmware/software, and I have set the min IAC positions to 0 for the idle range. I also changed my IAC parked position. This is where my question comes in. For the given operating temperature that I was at, I changed the IAC parked position down to a few different values. Then, I would key the engine off, then just turn the key back on (not the engine), and look at the IAC position to see if it matched the parked position that I just set. But, no matter what I set the IAC parked position to be, the computer reads IAC position of 100 when the engine is off and the key is on.
2. I have a manual transmission, and whenever I go to push the clutch in, the engine does not drop in RPM unless I do a quick mash of the throttle. I checked the throttle linkage to see if it was sticking, but that seems ok. Any suggestions for this?
Thanks in advance.
Danny Cabral
Loc: Ellington, CT
Reg: 11-03-04
06-23-12 03:50 PM - Post#2240561
In response to Devin
That's normal. When the engine is shut off, the C950 IAC fully seats, then moves to the 100 position (half-way).
When cranking to start, the IAC moves to the IAC Parked Position. I never liked it, but that's how it was designed.
I need more clues on this one. Does it seem EFI related?
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, A/C, Lentech Strip Terminator AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim-over steering, 4" lift, 35" tires |
Devin
Reg: 06-16-12
06-23-12 04:55 PM - Post#2240583
In response to Danny Cabral
I am not sure. I just know that when I come up to a stoplight, or if I am shifting gears, when I push the clutch in, the RPMs stay at some higher level than idle. After reading some threads on here, I thought maybe it was electrical noise related, but I am not sure since it will dive down to normal idle level if I very quickly romp on the throttle.
