tarps (7)
Username Post: 57 rear into 52 styline        (Topic#283045)
waubva52
Loc: Wind Lake.Wi
Reg: 04-01-04
06-23-12 11:40 AM - Post#2240495
I purchased a 57 rear and istalling into a 52 216 styline .I had the instruction to make this conversion but I lost them.Does anyone have this step by step instruction.I know some one posted then before. The rear had to be totally cleaned.and axle bearings replaced. I planning on using new springs.I see alot of differt choses Any advise
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
06-23-12 04:04 PM - Post#2240564
    In response to waubva52
Just redrill the spring pin locator hole 1 1/2 inches FORWARD of stock on the 57 housing, and 1/2 inch inward. BUT, if I were to do it again, I think I would NOT move the pin hole 1/2 inch inward; it makes the springs appear to lean in toward the center of the car. There may be some slight vaiants with different cars. In an old HOT ROD MAGAZINE I have, they drilled the locator pin hole forward 1 1/2 inches, but moved the perches outward 3/8 inch or so (seems like a lot of work to me). Butch/56sedandelivery.
53belair
Loc: Ellerslie, Georgia
Reg: 03-25-07
06-24-12 02:11 PM - Post#2240826
That's interesting. Makes sense that about 1/2 inch less might work.
06-25-12 07:33 AM - Post#2241095
In my opinion, the 55-56-57 Chevy rear axle housings are the best choice for converting a 49-54 Chevy to an open drive line. Unfortunately, they are becoming a little scarce. Of the three years (55-56-57), the 57 is just a slightly better choice, but any of the 3 is fine. With a properly rebuilt center section, and a posi added for more strength, these rears will stand up to juat about any healthy small block. The 57 rear in my 51 has been there since 67 and today the 51 has a healthy 383 and the 3.08 posi is doing just fine.
As mentioned above, to install a 55-7 rear into a 49-54 Chevy, just drill new holes 1 1/2in FORWARD and about 1/2in inboard of the existing holes. Use the 55-57 anchor plates/U-bolts and shocks for a 55-57 Chevy. I have installed Monroe air shocks for a 55-7 Chevy in the 51.
When I originally installed the 57 housing back in 67, I didn't know to drill new holes. Thus, the rear sits forward of center. Here is what it will look like if you don't drill new holes.
I ESPECIALLY prefer the 55-57 style rears because of the simplicity of changing/repairing the center section. They used the same style center section for 55-64 and parts as well as Eaton posi units are readily available for them. It is SOOOOOOOOOOOOO much easier to drop out the center section and put it on the workbench rather than work on the rear under the car!!!
This-------
------as opposed to this, is sooooooooooo much easier!
Tom Parsons
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
06-25-12 02:48 PM - Post#2241209
Tom, that photo looks just like my 52 Styleline with a 56 rear end. Previous owner put it in. A question, how does moving the spring locator hole forward move the wheel backwards, or to the center of the wheel well? On our 53 pickup we centered the wheel with a Nova rear and a 4 link rear by moving the rear end back 1 1/2 inch.
1975 Corvette, Original owner
1953 Chevy 3100 Pickup
1952 Chevy Styleline Coupe
http://sites.google.com/site/bluejaygarage/
4D50STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
06-25-12 03:06 PM - Post#2241213
    In response to coachfrank
Think about it, you move the hole forward and the whole rearend has to move backwards to drop in the forward hole.
Roger
1950 Style Line Deluxe 4 Door with a 1957 235
06-25-12 03:30 PM - Post#2241218
    In response to 4D50STYDLX
YEP, ultra simple!
Tom Parsons
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
06-25-12 03:36 PM - Post#2241220
Yep, Went down and looked at it!!!! Got it!!!!
waubva52
Loc: Wind Lake.Wi
Reg: 04-01-04
06-25-12 07:34 PM - Post#2241316
Thanks to all for the advise.I said previously that I need to get new springs, the old ones on the car have seen better days.When you made the swap did you use springs from the 57 or did you use the springs from the 51? One last thing I would like to know is spring perches any advise on them? Ken
53belair
Reg: 03-25-07
06-25-12 08:19 PM - Post#2241340
The 57 springs are not the right size to be a "drop in". Either get some new springs from eaton, better than new springs from posies, or do a complete change with a kit from one of the many providers.
Loc: Ellijay, GA
06-25-12 08:51 PM - Post#2241351
The SPRING PERCH is where you will be drilling the new holes.
06-25-12 09:26 PM - Post#2241363
My 57 housing is bolted to the original springs that were installed at the assembly plant in 1951!
Tom Parsons
06-25-12 09:26 PM - Post#2241364
    In response to bobg1951chevy
Correct!
Tom Parsons
53belair
Reg: 03-25-07
06-26-12 10:32 AM - Post#2241518
Here is the link to Eaton Springs. You can get several different spring rates (stiffness) and also 2" + or - ride height. Cost is approx. $300
http://www.eatonsprings.com/40-54chevroletcar.html
50hotrod
50hotrod
Reg: 07-25-11
06-26-12 01:22 PM - Post#2241574
    In response to 53belair
If you purchase a 2" leaf spring conversion kit everything will be a "bolt in" application.
53belair
Reg: 03-25-07
06-26-12 02:16 PM - Post#2241595
    In response to 50hotrod
The 2 inch conversion would be almost $200 more and there would be cutting and welding involved to move the spring perches on the axle. Otherwise it would be a bolt in. It's a great upgrade if the OP is interested in spending that kind of $$ and time.
waubva52
Loc: Wind Lake.Wi
Reg: 04-01-04
06-26-12 02:50 PM - Post#2241608
Thanks guys for setting me straight. I thought what you hook the spring to was the spring perch, and what I had to redrill was the spring pad.I got it. I will look at purchasing New 2" springs,redrill my "spring perch" install rebuilt 57 rear.I like this plan! Ken
Loc: Ellijay, GA
06-26-12 03:43 PM - Post#2241627
Ken, spring hooks to spring shackle.
50hotrod
50hotrod
Reg: 07-25-11
06-26-12 07:24 PM - Post#2241713
Here is a link.
http://www.ebay.com/itm/49-54-Chevy-Car-R ear-End-M...
Bill K.b
Loc: upstate NY
Reg: 10-24-05
07-02-12 10:46 AM - Post#2243626
Position the rear in the car, use some paint to mark where the holes should be, then drill them.
Those who can, do. Those who can't, criticize it on the internet.
1991 G20 van 5.7L - swap meet spl.
1993 3500 dually 5.7L NV4500 - tow truck
1991 Suburban 5.7
Plus cars for swap and sale
&yes, I once tried a frame swap on a 51 Chevy.
Execution time: 0.127 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:12 PM
