leon phelps
Loc: Croydon Manor, PA
Reg: 06-04-05
06-22-12 05:21 PM - Post#2240277
found a bag today marked rear window stops. I guess these somehow bolt to the rear side frames to stop the window from going too high.
Anyone have an idea or photo where they go? my mind will not recollect that far back.
thanks in advance.
leon phelps
Reg: 06-04-05
06-22-12 05:35 PM - Post#2240286
In response to leon phelps
novice66
Loc: san antonio,tx
Reg: 05-06-07
06-22-12 11:32 PM - Post#2240393
The bolt and washer look like the ones on mine that sandwich the glass to the track. So it prably is the outer piece meaning bolt/washer/ gasket / glass/ gasket / track / bump stop.
| <a href="http://www.picturetrail.com/uid9870823" target="_blank"><B& gt;Visit My Trail</B></a> |
leon phelps
Reg: 06-04-05
06-23-12 05:05 AM - Post#2240408
In response to novice66
any chance of a photo?
novice66
Loc: san antonio,tx
Reg: 05-06-07
06-23-12 06:49 AM - Post#2240431
Nope. Sorry, I never took one.
mikes66
Loc: Western New York
Reg: 05-08-04
06-23-12 07:08 AM - Post#2240433
Leon, there's a pretty good illustration in the Fisher Body Manual up in the Reference Section - p255 (Sec 8-23) - courtesy of ...... YOU!
66 Impala Convertible
leon phelps
Reg: 06-04-05
06-23-12 07:22 AM - Post#2240438
In response to mikes66
thanks, I looked at the table of contents and didnt find anything that looked like it would steer me in the right direction.
65_Impala
Reg: 12-29-02
06-24-12 09:10 PM - Post#2241003
Look for a slot in the inner panel (the metal the window crank mounts to) without anything in it. I would think those mount to the inner panel and "catch" some part of the window mechanism as it either goes up or down, bringing it to a stop. The slot would be long enough both the tab and the bolt would go into it and still allow some movement. The tab catches into the slot to keep the bracket from rotating. The slot would likely be vertical and likely near the top or bottom of the panel.
Edited by 65_Impala on 06-24-12 09:11 PM. Reason for edit: No reason given.
