Username Post: Zinc and oil        (Topic#282881)
jaxbeachdawg
jaxbeachdawg
Loc: Hilliard Florida
Reg: 05-07-03
06-19-12 06:31 PM - Post#2239275
I have been using pennzoil 10w30 for over 9 years on my 283 with no problems,is it really necessary to change because of the less zinc added to oil these days,I hate to change oil brands after all this time
1957 Chevrolet 4 Door Bel Air Sedan,283 Power Pack,Powerglide,Power Brakes and Steering,81,000 Documented Miles,Proudly Driven In Loving Memory Of My Son Cory(1983-2000)
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
06-20-12 06:26 AM - Post#2239389
    In response to jaxbeachdawg
TODAYS OILS WORK FINE IN OLDER CARS no need to worry about zink
nstlga
Loc: Colorado
Reg: 12-01-05
06-20-12 07:52 AM - Post#2239422
    In response to arnieg141
Just read an interesting article that says current oil choice depends on whether or not the engine has been rebuilt or is truly original, and how much you drive it these days. These things coupled with frequency of change can all dictate what you need to do additive wise, if anything to raise the zinc level.
He who dies with the most toys doesn't necessarily win, but had more fun getting to the finish line.
beejay
beejay
Loc: Pflugerville, Texas
Reg: 06-01-04
06-20-12 01:20 PM - Post#2239509
    In response to nstlga
If valve seats have been ground, then you need ZDDP until they harden. On old engines and not have valve seats ground, no.
Bruce
http://www.picturetrail.com/beejay3/"
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
06-20-12 04:18 PM - Post#2239575
with the stock cam todays oil is o.k. when you have a cam with an agressive profile,zink additive becomes more of a necessity to preserve the lobes and lifters.i put some in all of my old engines every oil change.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
06-20-12 05:41 PM - Post#2239610
    In response to beejay
Beejay, Thats lead not zddp. Zddp is for flat tappet cams.
Roller lifters don't need zddp so thats why it's not in modern oil.
Keep using your new oil in a flat tappet cam engine and you will need a new cam eventually.
57 Bel Air 2dr Ht 327 700r4 http://www.picturetrail.com/tmneid
WSSmolik
WSSmolik
Loc: PA
Reg: 01-25-01
06-20-12 06:50 PM - Post#2239633
    In response to 57tim
From what I understand, oil is forced-away from the cam lobe-lifter interface, causing wear. The ZDDP compound in oil "plates" this high-pressure surface to greatly reduce wear. The cam lobe-lifter contact area is infinitesimally small, so it is critical that this area receives the proper lubrication. Newer technology uses rollers in contact areas such as this, which gives the contact areas a full bearing surface.
'56 210 Townsman wagon 6cyl/3spd OD | '58 Impala Sierra Gold 348
06-20-12 07:07 PM - Post#2239641
"If valve seats have been ground, then you need ZDDP until they harden."
Valve seats don't self harden.
And the oil used does not affect valve seats. If you have oil on them, your engine is worn out and it's too late.
The issue with ZDDP is with camshaft/lifter wear.
My opinion is that if you have a stock engine that's been running for some miles, you don't need to panic or change to a different oil. Might be different if you had a performance camshaft and increased valve spring force. Certainly different if you are going to rebuild in the future, or modify your valve train.
models916
Loc: Addison, IL
Reg: 05-28-10
06-21-12 05:20 AM - Post#2239738
What does zinc in the oil have to do with the valve seats? Oil never touches the valve seat. You're talking about lead in the gas. Modern oil is not good for a flat tappet engine without ZDDP additive.
ThumperNZ
ThumperNZ
Loc: New Plymouth, New Zealand
Reg: 07-08-07
06-21-12 02:52 PM - Post#2239865
    In response to models916
The ZDDP in oil is required by the lifters to get a scuff protection to enable the cam profile (which is slightly sloped across the lobe) to rotate the lifters (the lifter is slightly rounded on the face).
This enables the cam profile/lifter interface to always be different so that a wear pattern is minimised. The function of the ZDDP is to help with this action, the modern oils are "more slippery", so there is a danger that the lifter may not rotate, and it could wear out in 5mins.
Shell Rotella 15W-40 used to have higher ZDDP when it was CI-4 spec but it has now been lessened to comply with the EPA requirements.
Would I use normal oil with the lessened ZDDP in a used engine?
NO, I see the results of this in my engine shop every week, which has led me to recommend to the average JOE, to go Roller cam, hydraulic or solid.
If the customer is a purist, or someone who will listen and use ZDDP, I have no problem with the flat tappet cams.
'57 Model 1037D COMPLETED! (but are they really?
57tim
57tim
Reg: 11-09-01
06-24-12 02:48 PM - Post#2240841
    In response to ThumperNZ
Thanks for that excellent explaination You should have highlighted the "who will listen".
Bad270
Loc: Weeki Wachee, Fl. 34607
Reg: 08-04-07
06-27-12 09:25 AM - Post#2241904
http://www.redlineoil.com/product.aspx?pid=121&...
A bottle of this is good for 2 oil changes-you can get it at: www.fifthaveinternetgarage.com
models916
Loc: Addison, IL
Reg: 05-28-10
06-28-12 08:00 AM - Post#2242245
    In response to Bad270
You can get Rislone ZDDP and most auto parts stores. Add it to what ever oil you want and forget about it! ZDDP is ZDDP
http://www.barsproducts.com/blog/the-straight-sco o...
Bad270
Reg: 08-04-07
06-28-12 03:29 PM - Post#2242347
Sounds like a better way to go
57tim
57tim
Reg: 11-09-01
06-28-12 04:32 PM - Post#2242356
I think we beat this to death Use whatever oil you want and then when the engine craps out rebuild it to not use ZDDP and your problems are solved.
Me, I am going to continue Valvoline VR-1. So what if it cost more. I use 5 quarts per year. $30 bucks and I don't worry if I have too much/too little/ will it wash off/ etc.
models916
Loc: Addison, IL
Reg: 05-28-10
06-29-12 05:19 AM - Post#2242525
VR1 is API certified as SM rated (check the bottle and you’ll see), which means it has reduced levels of zinc. It is a racing oil for modern engines, not older flat tappet.
57tim
57tim
Reg: 11-09-01
06-29-12 05:03 PM - Post#2242751
The Valvoline.com web site for VR-1 street racing oil says high high zinc/phosphorus for extreme wear protection including flat tappet applications.
I rest my case.
models916
Loc: Addison, IL
Reg: 05-28-10
06-30-12 11:08 AM - Post#2242967
What does High mean? .14/.13 as listed on there site is about half of what is in Lucas racing oil. I would not use a SN rated oil without an additive in an expensive collector car engine. API SN rated oil by law has to have reduced levels of ZDDP.
57tim
57tim
Reg: 11-09-01
06-30-12 03:15 PM - Post#2243036
Ok, I sent am email to VALVOLINE. Hopefully we can resolve this once and for all.
Bad270
Reg: 08-04-07
06-30-12 06:39 PM - Post#2243105
This may be no help but I have a bottle of VR1 50W in front of me and it says "Ashless anti-wear additives and ZDDP provide ultimate wear protection". Just doesn't say how much ZDDP is in it.
Interesting discussion
Bud
models916
Loc: Addison, IL
Reg: 05-28-10
07-01-12 07:04 AM - Post#2243245
I think the straight wt VR1 is rated different than the multi.
Bad270
Reg: 08-04-07
07-01-12 07:18 AM - Post#2243252
Thumper you nailed it!
http://www.aa1car.com/library/api_motor_oil _classi...
57tim
57tim
Reg: 11-09-01
07-01-12 05:44 PM - Post#2243458
20-50 VR-1 has the same statement. We will see if they answer the email I sent Saturday.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
07-03-12 12:29 PM - Post#2244063
Not correct. From Valvoline's website:
What solutions does Valvoline offer to the zinc issue?
Valvoline VR1 Racing Oil contains 75% higher zinc than SM motor oil with a balanced additive package designed to work in both racing and street-legal applications. This product will protect older style push-rod and flat tappet engines. Valvoline provides this product in both multi and mono viscosity grades: 20w50, straight 50, 10w30, straight 30, straight 40, and straight 60.
Valvoline VR1 Racing Oil contains .13 percent of zinc and .12 percent of phosphorus compared to the Valvoline "Not Street Legal" Racing Oil which contains .14 percent of zinc and .13 percent of phosphorus.
Comments from Valvoline on http:/www.latemodelracer.com:
We see a lot of references to the API Service "SM" rating, being the main cause for catalytic converter damage. SM is basically just a gasoline rating. The S stands for Spark ignition, which refers to the ignition for gasoline type vehicles. When an oil has an SM rating, that just plainly means that the oil passed the specific API (American Petroleum Institute) test requirements to obtain this specification. It has nothing to do with catalytic converters. The rating that stands out on conventional motor oils, (Premium conventional, Durablend, & Synpower) is the GF-3 and GF-4 ratings. These are energy conserving ratings that are necessary because of the Environmental Protection Agency mandating federal standards to further reduce emissions, beginning with '05 vehicles. These are the ratings that make the oil safe for catalyst effectiveness, and these ratings are not found on the VR1 Racing Oils due the ZDDP additive content, not API Service "SM."
Real Hot Rods have a Clutch!
1969 C-10 pickup: 350, TH350
My car pictures
Edited by MikeB on 07-03-12 12:53 PM. Reason for edit: No reason given.
models916
Loc: Addison, IL
Reg: 05-28-10
07-03-12 02:26 PM - Post#2244090
    In response to MikeB
Sounds like double talk. API site says S stands for SERVICE and C stands for COMMERCIAL. Doesn't say anything about ignition. Should probably ask if the VR1 is a blend of dyno and syn. Could be the ZDDP spec is only for the dyno part of the oil.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
07-04-12 08:14 AM - Post#2244383
Both "S" and "P" are API service ratings. (Edit: I meant "S" and "C".)
"S" actually means "spark", as in spark ignition.
The "C" stands for "compression" as in compression ignition in a diesel engines.
My car pictures
Edited by MikeB on 07-05-12 12:11 PM. Reason for edit: No reason given.
models916
Loc: Addison, IL
Reg: 05-28-10
07-04-12 12:58 PM - Post#2244489
API site says S stands for SERVICE and C stands for COMMERCIAL. It's their site and their rating, they should be correct.
07-04-12 05:02 PM - Post#2244554
Do you have a link?
The stuff MikeB talks about has been around a long time.
My guess is somehow we've got apples and oranges. If both are right, they're not talking about the same thing. But I don't know for sure.
I have no reason to doubt the Valvoline information.
models916
Loc: Addison, IL
Reg: 05-28-10
07-05-12 05:23 AM - Post#2244655
    In response to Rick_L
Try this
http://www.api.org/certification-program s/engine-o...
07-05-12 11:45 AM - Post#2244752
I'm not sure I see a contradiction except possibly semantics.
Execution time: 0.2 seconds.   Total Queries: 26   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:49 AM
