Username Post: 94 c1500 5,7 idle issues        (Topic#282875)
jz512
Loc: Austin TX
Reg: 09-19-11
06-19-12 05:49 PM - Post#2239259
Battery died after sitting all day..went to get it charged and when i started the truck it bogged and died...anyone know why...was running fine a few days ago...sounds real rough at idle and then just dies...i can keep her on if i keep on the gas..but still handles really rough..any suggestions
94 c1500 5,7 burb 2wd
navygunner08
navygunner08
Loc: New London, CT
Reg: 02-13-11
06-20-12 05:30 AM - Post#2239380
    In response to jz512
Ok, first things to check... 1- Throttle Position Sensor, there is a section in the FAQ that will explain how to check it. 2- Coolant Temp Sensor, just replace it. They go bad frequently and it can cause all kinds of problems. They are fairly inexpensive as well.
1994 K1500 Z-71
jz512
Loc: Austin TX
Reg: 09-19-11
07-03-12 10:08 PM - Post#2244268
    In response to navygunner08
turned out to be tps bought both sensors and will install coolant temp also...running 100 again
Execution time: 0.086 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:55 PM
