Username Post: steering column orientation confusion        (Topic#282871)
leon phelps
leon phelps
Loc: Croydon Manor, PA
Reg: 06-04-05
06-19-12 02:59 PM - Post#2239197
Hello, got my wiring harness from Donny. Trying to replace it in my steering column.
I have everything together and seem to be off.
I see the tang on the dash side. It should go in the hole in the column, or I think it should.
If I put it in the way it is now, the turn signal would be on the opposite side.
I am sure this is simple or I am missing something.
Metallica Fuel
nicke
nicke
Loc: Spokane, Washington
Reg: 01-06-12
06-19-12 03:04 PM - Post#2239200
    In response to leon phelps
Hmmm, Yes Leon, I just put mine in and the tang in the dash lines up directly with indent in the column to lock it in place and keep it from rotating. Is is possible that you have your switch assembly and upper collar 180 degrees out?
-Nick
65' Impala SS- Pics
leon phelps
leon phelps
Reg: 06-04-05
06-19-12 03:13 PM - Post#2239204
    In response to nicke
cant be 180 out, it has a twist lock in it. The collar twists then locks into place. If it is not locked, the turn signal arm will not go through collar. The lower part of the collar is fixed to the center and it attaches to the inside in one place, some twist but not close to 180 degrees.
Metallica Fuel
dadstoy
dadstoy
Loc: Lewisburg Ohio
Reg: 04-01-07
06-19-12 03:48 PM - Post#2239219
Does this help?
Larry.
1965 Impala convertible 396
1965 Impala 9 pass wagon 283
leon phelps
leon phelps
Reg: 06-04-05
06-19-12 04:12 PM - Post#2239229
    In response to dadstoy
figured it out. there are three slots in the top collar that only two are used to slide into the tube.
Next I got to fix my super duper american autowire harness that didnt have the correct connector on it.
one of those days.
Still no horn.
we wait til night time to get the voltmeter out and see if anything else works/does not work.
Metallica Fuel
Execution time: 0.111 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:11 PM
