nellis003
Loc: Brookfield, IL
Reg: 09-27-07
06-19-12 10:33 AM - Post#2239133
Hi all,
The water pump on my '33 Chevy seems to be leaking pretty badly. As best as I can tell, it's coming from around the pump shaft rather than the pump-to-block gasket.
It looks like the pump is similar to the Model As where it has a nut you can loosen and then you insert packing material (lead or teflon) around the shaft. But I can't seem to find any source for the packing material.
Can anyone tell me if (a) it does actually work this way, and if so (b) where I can find a packing kit?
Thanks,
Nick
Nick
Brookfield, IL
1950 3100 Hot Rod
1953 3100 Late 235
WagonMan
Loc: SW Kansas
Reg: 10-26-04
06-19-12 11:53 AM - Post#2239150
In response to nellis003
If it is indeed made that way, have you checked the plumbing section of a well stocked hardware store? Water pump packing is water pump packing whether automotive or stationary pump.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
53 Chevy 3100 (bought '96)
-250 I6/TH350 |
buggymangp
Reg: 08-26-08
06-19-12 11:58 AM - Post#2239151
In response to WagonMan
you can also try the filling station.
if you cant tighten down the nut around the shaft to stop the leak most likely the shaft is worn were the packing would ride and no amount of packing will stop the leak. the filling station also sells rebuilding kits for pumps with a new impeller
