tarps (7)
Username Post: 84 el camino 3.8 question?        (Topic#282842)
93chevyz71
Reg: 01-28-12
06-18-12 07:02 PM - Post#2238925
my dad has a nice ride but some times when you first start it. it puffs a little smoke. is it valve seals? i heard of puttin some atf fluid in the oil and gas will that work? or would it be best to have the valve seals replaced?
Edited by 93chevyz71 on 06-18-12 07:03 PM. Reason for edit: No reason given.
06-18-12 07:10 PM - Post#2238931
    In response to 93chevyz71
More than likely the valve seals. It could also be clogged oil drain back holes in the heads. My friends truck used to have this happen occassionally. The oil sits in the heads and it also sits on the valve seals and seeps past them. It would smoke on startup and if you sat and idled too long. Didn't do it under normal driving conditions. Best to just replace the seals if they are bad.
Execution time: 0.082 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:26 AM
