tmsnyder
Loc: Buffalo, NY
Reg: 06-13-06
06-18-12 11:31 AM - Post#2238736
If it were up to you, which would you choose to put in a '56 chevy:
Muncie M-20
Muncie M-21
New Process A833 (http://www.classicjunkyard.com/new_process_a833.htm)
I'm running a stock 3 speed OD now, picked up a A833 to swap in. It should put the shifter in a good spot in front of the bench seat. It will require putting in a tranny support which I got from Speedway.
But there's a guy with some muncies for sale nearby, one of those would swap right in w/o the tranny support but I'd have to get the Hurst shifter.
The rear end is a 3.70 stock rear end.
'56 Chevy 4dr 210 327ci 3-speed on-the-floor OD
'97 GMC K1500 Suburban Diesel |
Edited by tmsnyder on 06-18-12 11:34 AM. Reason for edit: No reason given.
This
Forum is Sponsored by
Pistol
Loc: Terryville, Ct.
Reg: 11-11-02
06-18-12 03:05 PM - Post#2238840
In response to tmsnyder
On the M20 and M21 the gear ratio and the ratio spread between the gears other than that they are pretty much the same
A833 is a lot cheaper to setup than a M20/M21
Pete
Awl speeling misteaks r myn
57 BelAir 2DRHT My-Pics |
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
06-18-12 11:46 PM - Post#2238987
What about a Saginaw 3 speed overdrive? I use those in my 57's with some linkage modification.
tmsnyder
Loc: Buffalo, NY
Reg: 06-13-06
06-19-12 02:03 PM - Post#2239184
In response to f.i.57chevynut
That's what I have now, there's no syncho on 1st gear. It's not much fun to drive.
I already have the A833 tranny, bellhousing, shifter sitting on the floor in my garage. Also the crossmember for the tranny support, so it would be supported by the stock front supports and the tranny crossmember.
The A833 tranny has almost the same exact gear ratios as the TH700 OD tranny. Can anyone speak to the combo of this, a 327, and the 3.70 rear end on 215-75-r15 tires?
But now I see a muncie m-20 and m-21 for sale locally. Those would bolt right in with no crossmember, I'd just have to buy the special hurst shifter to clear my stock bench seat.
Too many options.
awsum55
Loc: O.P. Kansas
Reg: 09-27-01
06-19-12 03:10 PM - Post#2239203
Go for the M20 just because it has a lower first gear and it's better for a heavy car. It also helps if you want to go with a 3.08 rear gear because you won't have to slip the clutch as much when you take off from a stop. If you have a stout engine it won't make much of a difference which first gear you have.
Five things that you cannot recover in life:
* The Stone after it's thrown
* The Word after it's said
* An Occasion after it's missed
* The Time after it's gone
* A person after they die |
tmsnyder
Loc: Buffalo, NY
Reg: 06-13-06
06-19-12 08:11 PM - Post#2239303
In response to awsum55
The A833 gear ratios are 3.09, 1.67, 1.00, 0.73 so it would actually be better at getting the car up and moving. The M-20 has 2.56, 1.91, 1.48, 1.00 gearing.
I have 3.70 rear end, no plans of changing that, just had it rebuilt actually.
f.i.57chevynut
Reg: 03-04-09
06-20-12 12:03 AM - Post#2239350
The Saginaw OD I am using is a 66 and later, all synchro type.
This
