Username Post: Carbuertor selection        (Topic#282753)
kstandri1963
Reg: 11-18-11
06-17-12 12:24 PM - Post#2238291
Hi All:
I know I have seen this question before but I cannot find the post so here it goes. I have a 1963 Impala with a 327 300HP engine. It also has a Muncie 4 speed. I have a 1963 carter carburetor that has seen better days and after 3 rebuilds and 1 remanufacture it still does not work right. I am looking at getting an Edelbrock carburetor to replace it. I am trying to decide between the 500 and 600 CFM versions. What are the pros and cons of both?
Thanks,
Ken
jt283impala
jt283impala
Loc: Arlington Hts IL
Reg: 07-04-03
06-17-12 01:25 PM - Post#2238306
    In response to kstandri1963
I have the 600 cfm and Performer manifold on my 283. I was concerned when I first installed the 600 cfm that it would be too much for the 283, but I have had no performance problems. The car runs so much better with the Edelbrock, than with the rebuilt stock ones.
del.impala
Loc: delaware
Reg: 04-13-11
06-17-12 01:33 PM - Post#2238309
The 600 cfm carburetor is the way to go. It'll give you great throttle response .
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
06-17-12 06:17 PM - Post#2238435
i'm running a 600 cfm edelbrock and a performer intake an the 327 in my 65 el camino. works well.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
dwmtl1000s
Loc: Woodbury, MN
Reg: 10-22-10
06-17-12 07:04 PM - Post#2238452
    In response to 62chevy427
64 327 owner hear as well running the 600 to!
carbking
carbking
Loc: Missouri
Reg: 06-14-03
06-18-12 05:53 AM - Post#2238601
  • kstandri1963 Said:
Hi All:
Thanks,
Ken
Have you considered the possibility that if, after 3 rebuilds and a remanufacture that you are still having issues; that maybe you have other issues than the carburetor?
The original Carter is superior in design, reliability, and performance to either of the clones, but your decision.
However, Carter rated the 3721s (factory replacement for the 1963 327/300 S/T) at 575 CFM.
Jon.
Good carburetion is fuelish hot air!
The most expensive carburetor you will ever buy.....is the incorrect one you attempt to modify!
If you truly believe "one size fits all", trying walking a mile in your spouse's shoes!
kstandri1963
Reg: 11-18-11
06-22-12 05:38 PM - Post#2240287
    In response to carbking
I took it to a mechanic I trust and he advised me to replace the carburetor. He worked on it for days and got it working for a tiime, but when sets for a week or so and the problems come back. I had a edelbrock on it while I was having the carter remanufactured and it ran fantastic. I the problems continues to persist I may foot the bill for fuel injection.
kstandri1963
Reg: 11-18-11
06-30-12 05:20 PM - Post#2243078
I would like to thank everyone for their input. I have gone through my car one last time before springing for a carburetor and nothing has changed. It appears that fuel is somehow leaching down into the engine again. It was doing that once before and I sent it to national carbs for a remanufacture. I will just change out the caburetor.
BigCoop64
BigCoop64
Loc: Milwaukee,Wisconsin
Reg: 02-19-04
06-30-12 08:24 PM - Post#2243139
i may be on the late show,but what type of problems are you having? maybe its not the carb,considering youve been through a few rebuilds and a reman. maybe someone could/will have a differnet solution if we knew what the problem was.
1964 Impala
Original 283.030over
powerglide,edelbrock/holl y
Pete Jackson gear drive
HEI/msd 6al
2.25" exhaust w/50series flowmasters
other cars:2003 Monte Carlo LS
1996 Dodge Stratus
http://community.webshots.com/user/bigcoop64
kstandri1963
Reg: 11-18-11
07-01-12 05:22 AM - Post#2243218
    In response to BigCoop64
My 1963 Carter carburetor has been giving me problems for years. After the carburetor started leaching gas into the engine 6 years back I sent it to National carbs and they remanufactured it and things got better. I gave my car to a restorer about 4 years ago to get rid of rust, repaint and update the brakes and steering. He went out of business and I lost about $30,000 not to mention my car was in sad shape. I he had it for a couple of years and did replace some bad metal, put on front disk brakes and put it back together. I have been working with a mechanic I trust to try to get it running right. The carburetor has been giving me fits. The car has been hard to start, trying to stall when I press on the gas hard, and sometimes I can smell gas. The carburetor has been rebuilt again from top to bottom, the accelerator pump replaced twice, and adjusted numerous times in the last year. I checked my plugs again this week and they were wet and fouled out. Everyone of them. For now I am going to replace the carburetor and put this one on the shelf. I have other issues I need to address.
kstandri1963
Reg: 11-18-11
07-08-12 01:34 PM - Post#2245761
I had a very successful carburetor change out and the car runs better that it has in years. I have one more question on the issue.
How do I plug the hole in my passenger side exhaust manifold where the choke tube was?
doubleE
doubleE
Loc: Eagan MN
Reg: 06-02-03
07-09-12 05:22 PM - Post#2246312
I forced a bolt (screwed in)into the hole, cut it off flush with a hack saw, hit it a few times with the MIG welder followed by a little touch up grinding. Once paint with high temp manifold paint, looks like it was only a boss in the casting.
Eric
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
07-09-12 07:53 PM - Post#2246376
    In response to doubleE
You don't need to plug it unless the tube inside is broken/missing.
The top manifold had the tube removed and the holes welded up. The bottom is a new manifold showing the tube.
- Dave
1964 Impala 4 door sedan
My Impala Restoration Blog
kstandri1963
Reg: 11-18-11
07-11-12 03:23 PM - Post#2247122
    In response to dcairns
Thanks. My exhaust manifolds are new or less than 2 years old. I will just watch for a change in sound.
Execution time: 0.137 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:05 PM
