Mark C 65SS
Loc: Melbourne Australia
Reg: 01-20-12
06-17-12 05:38 AM - Post#2238147
Hi just replaced my engine harness with a new American Autowire HEI kit but i now cant get the wipers working now any ideas ? it dosent seam to be getting a feed now after changing from original harness & they were working previously.
Any help appreciated Cheers Mark
Sorry it's a 65SS
Edited by Mark C 65SS on 06-17-12 05:40 AM. Reason for edit: No reason given.
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
06-17-12 07:48 AM - Post#2238200
In response to Mark C 65SS
Did you plug the yellow wire from the new engine harness into you original wiper harenss? Take a test light and check voltage on that yellow wire with the key on. Let me know what you find.
Donny
Mark C 65SS
Reg: 01-20-12
06-18-12 04:02 AM - Post#2238571
In response to aawtech
Hi Donny
Thanks for your help yes I plugged the yellow into the wiper motor & checked power tonight when I got home with key on & nothing same as with key off it has a small amount of feed 0.3 volts on one of those fluke digatal meters i tried with wiper switch on in both on positions as well as in off position all the same
Edited by Mark C 65SS on 06-18-12 04:03 AM. Reason for edit: No reason given.
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
06-18-12 06:37 AM - Post#2238616
Hi Donny
Mark,
The switch has nothing to do with it. The yellow wire at the motor is hot all the time when the key is on. The switch switches ground, not power with GM products. OK, now that you've determined that you have no voltage on the yellow wire at the motor, go check both sides of your wiper fuse inside the car with the key "on". You should have voltage on both sides of that fuse. Let me know what you find.
Donny
Mark C 65SS
Reg: 01-20-12
06-19-12 10:04 PM - Post#2239326
Hi Donny,
Checked all the fuses today as not 100% sure which is the wiper fuse.
All except the 3rd fuse from the bottom have power on both side with key on.
The 3rd fuse from the bottom is dead on both sides of the fuse, had a look to make sure terminal plug was on correct it seams ok.
By the way was quite impressed by the quality of & fit of the harness well done & thanks for your help, cheers Mark
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
06-20-12 06:20 AM - Post#2239388
Hi Donny,
The fuse third up from the bottom is the one for dash lamps and will be dead unless the lights area turned on. The top fuse is the one for the wiper motor. With the key "on", check voltage at the yellow wire on the engine harness assembly and then check voltage at the bulkhead assembly where the yellow goes into the firewall. Let me know what you find.
Thanks, Glad you were happy. Hopefully, we get you squared away here pretty quickly. By the way, were things working before you replaced the engine harness? Did you do anything to disturb the wiper harness or switch in the dash by any chance?
Donny
Mark C 65SS
Reg: 01-20-12
06-20-12 03:51 PM - Post#2239566
Hi Donny,
The wipers were working when i removed the old harness, i'll check the bulk head connector tonight when i get home from work, i dont think i disturbed the wiper switch but i had to remove & reinstal the key switch as one of the wire broke off when i removed the plug to fit the new HEI wire, so i'll double check i havent disturbed it tonight, thanks for your help Regards Mark
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
06-20-12 04:51 PM - Post#2239588
Did you re-install the wire that you removed from the ignition back into the 3 inch pigtail on the new wire? If not, that's the problem as you may not be feeding the dash, just the HEI.
Mark C 65SS
Reg: 01-20-12
06-20-12 10:46 PM - Post#2239704
Hi Donny,
Yep i fitted that wire into the new terminal on the New pink wire for the HEI
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
06-21-12 07:29 AM - Post#2239764
I have no idea why you would not have voltage out at the yellow wire then Marc. Let me know where you do and don't have voltage after you check, OK?
Donny
Mark C 65SS
Reg: 01-20-12
06-22-12 04:53 PM - Post#2240267
Hi Donny,
Think i found the issue I removed the top wiper fuse & the terminal seamed a little rusty so I cleaned it up with a bit of emery paper & gave it a spray of contact cleaner & it's now working looks like maybe I should plan to Change the fuse box down the track, any way thanks very much for all your help & advise it was very appreciated owe you a beer thanks Mark
