Username Post: Differential question        (Topic#282684)
blue92
Loc: Tennessee
Reg: 06-16-12
06-16-12 11:08 AM - Post#2237838
I have a 92 S-10 standard cab, 2 WD, 4.3 automatic. It has a 3.08 diff. What other S-10 p/u or Blazer (or anything else) diffs will swap into it? Would like a 3.73 or 4.10.
The only handicap in life is a bad attitude - Scott Hamilton
SleeperSS
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
06-16-12 12:26 PM - Post#2237861
    In response to blue92
If you can find one, a rear from a 98+ 2wd Blazer will bolt in with the added benefit of disc brakes. Any S10 rear will fit as long as it's from a 2wd.
'96 S-10 SS
'02 BlaZeR2
S10Fanatic
S10Fanatic
Loc: Eastern NC
Reg: 09-18-11
06-16-12 12:46 PM - Post#2237869
95 or newer Ford Explorer will give you disc brakes on the rear and is almost a direct bolt in and it's virtually bullet prof.
Hear is plenty of info.
http://www.v8s10.org/forum/viewtopic.php?f=19&...
blue92
Loc: Tennessee
Reg: 06-16-12
06-19-12 08:28 AM - Post#2239094
    In response to SleeperSS
Thanks for the info. Actually, I was just looking to swap the diff it self, not the entire housing.
Senior Chevytalk Moderator
06-19-12 09:39 AM - Post#2239108
You mean the gear set. The ring and pinion are sold as pairs. Suppliers include www.summitracing.com or www.jegs.com. Your local parts store can order you a set. 3.42 gears are common. My Jimmy as 3.42 gears with a 4.3. I have a full size C10 with 3.08s and 360+ HP. The 4.3 pulls weight better than the full size truck.
Do run large tires? 4X4? Are you planning to tow toys around? I think you would be happy with 3.42 gears. Do you know how to set the lash?
'96 GMC Jimmy LS
blue92
Loc: Tennessee
Reg: 06-16-12
06-19-12 08:46 PM - Post#2239317
Thanks for the info. I'm running 18" wheels but not 4x4. No towing. I have a buddy that is a mechanic that can make the swap.
06-20-12 07:02 AM - Post#2239407
I run 255/60R17 wheels on my Jimmy. They are 29" tall. So about 2" taller than stock. My Jimmy drives okay with 3.42 gears. I know 3.73 gears would be better due to the large tires. I frequently pull a popcamper that weighs about 1500-2000 lbs loaded. My Jimmy pulls at 70 MPH with very little trouble. Between your choices, 3.73 gears are the better choice.
'96 GMC Jimmy LS
blue92
Loc: Tennessee
Reg: 06-16-12
06-21-12 01:54 PM - Post#2239853
Execution time: 0.09 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:04 AM
