Username Post: Differential Ratios        (Topic#282653)
Old Chevy Soldier
Gold Supporting Member
Loc: Central Montana
Reg: 03-12-12
06-15-12 06:42 PM - Post#2237619
Hello Gentlemen (and Ladies),
I am working on a 41 chevy. One of the popular drive train conversions is to a SBC-700R4-S10 Diff. I was told that it is possible to detemine the diff. ratio by using a code that is on a label in the glove box or on a tag on the diff. Can anyone explain more clearly the location of the codes and how to translate?
Life is to short to ride an ugly horse or drive a Ford
Senior Chevytalk Moderator
06-15-12 09:18 PM - Post#2237671
    In response to Old Chevy Soldier
Yes, using the glove box RPO codes. You can determine gear ratios. The most common ratio is 3.42. Do you. have the codes?
'96 GMC Jimmy LS
Old Chevy Soldier
Reg: 03-12-12
06-16-12 01:04 AM - Post#2237715
gchemist,
Thanks for the response. No, I do not have the codes. I would also like to know if the S10 has the 5 on 4 3/4 lug pattern.
65327
Loc: ohio
Reg: 05-13-12
06-16-12 05:14 AM - Post#2237741
One way to check ratios is to jack up the car and put the trans in its highest gear for a 1.1 ratio, turn both rear tires one full rotation at the same time and count how many times your driveshaft turns. It,s not exact but real close.
3 1/2 turns would be around a 350 gear and so fourth. It works!
Chevytech
Reg: 04-25-04
06-16-12 07:51 AM - Post#2237787
Axle ratio by RPO code on the sticker in the glove box.
GM1 = 2.59
GU2 = 2.73
HC2 = 2.76
HE3 /G44 = 3.07
GU4 = 3.08
GU5 = 3.23
GU6 = 3.42
GT4 = 3.73
GT5/GT8 = 4.10
HC4 = 4.56
If the it has been altered from stock let us know about that too.
SleeperSS
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
06-16-12 09:24 AM - Post#2237808
    In response to Chevytech
As a side note, G80 is the much maligned Posi/Gov-Loc. Mine is still going strong at 239K.
'96 S-10 SS
'02 BlaZeR2
Old Chevy Soldier
Reg: 03-12-12
06-16-12 05:56 PM - Post#2237984
    In response to SleeperSS
65327,Chevytech, SleeperSS,
Thank you for the responses. I think I have enough information to proceed.
06-17-12 04:36 AM - Post#2238133
Since you probably have to change the oil in it, look for a stamp on the ring. It will have the number of teeth stamped on it.
'96 GMC Jimmy LS
Execution time: 0.088 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:23 AM
