frankthetank
Loc: Lodi California
Reg: 02-22-11
06-14-12 10:26 AM - Post#2237097
I disconnected my heater core a little while back on my 63 as it had sprung a leak. For some reason the cab of my car still reaks of coolant. Could it be the core still mounted in the car retains coolant causing the smell?
1963 Chevrolet impala sport coupe
2006 Chevrolet silverado crew cab 2wd |
Edited by frankthetank on 06-14-12 10:27 AM. Reason for edit: No reason given.
Mad Joe
Loc: Wichita Falls, Tx.
Reg: 05-09-07
06-14-12 12:52 PM - Post#2237136
In response to frankthetank
I wouldn't think so. It should have evaporated or leaked out by now. You might check the carpet and clean it real good. Make sure nothing is gowing underneath it.
frankthetank
Reg: 02-22-11
06-14-12 09:05 PM - Post#2237281
In response to Mad Joe
Thanks bud I'm going to pull that carpet bk tomorrow.
Mad Joe
Reg: 05-09-07
06-15-12 02:51 PM - Post#2237528
Frank:
Let us know what you find. It it was my car, I'd also blow air through the core just to make sure nothing is in there. It may take some cleaning with some smell good soap to get the stink out.
It sounds to me you had a lot of fluid leak on the floor.
junky
Reg: 06-27-10
06-15-12 03:54 PM - Post#2237549
Ethel Glycol (antifreeze) is next to impossible to get out of a carpet. You would save yourself a lot of trouble and time by replacing the carpet. In the end, you will be doing that anyway. I speak from experiance...
Edited by junky on 06-15-12 03:55 PM. Reason for edit: No reason given.
Chevrobert
Loc: Braintree,Ma. USA
Reg: 06-14-08
06-15-12 04:38 PM - Post#2237565
Frank:
Before you replace carpet you might try,
Grinding up some speedy dry into a powder and laying it under the carpet for a few days that should absorb any residual/minuscule coolant.
Also your local HVAC wholesaler will have some anti smell stuff(AKA?????) they use for oil spills.
Good luck
Bob
1964 Impala SS 327 4 Forward Gears & 1 Reverse
See the USA in your Chevrolet.. |
frankthetank
Reg: 02-22-11
06-18-12 10:50 AM - Post#2238716
In response to Chevrobert
I checked it out today and everything seems to be good and dry under the carpet. I did however notice that there is a dark stain around were the floor mat sits on the carpet. Looks like dampness but I don't think it's wet, possibly a stain from the leaked coolant? Any how I rolled all the windows down on it and left the carpet peeled back in that corner to let it vent out.
frankthetank
Reg: 02-22-11
06-18-12 10:58 AM - Post#2238722
There's some bags filled with some anti moisture stuff you can put in your car to help keep the moisture out. I remember someone on this forum was talking about them a good while back. Anyone know what they are called?
roccaas
Loc: Savannah, Georgia
Reg: 05-01-11
06-18-12 01:47 PM - Post#2238808
Damp Rid?
Also, if you've had a long time leak, the carpet and padding may be full of mold, spores, fungus, bacteria, etc.
Clean it well, try a garden shop for some Yarrow branches with the leaves still on. Along with charcoal it might clear the air.
For the good old American lifestyle: For the money, for the glory, and for the fun... mostly for the money.
64 impala ss
Reg: 02-03-10
06-18-12 02:00 PM - Post#2238817
In response to roccaas
I've heard charcoal and/or fresh ground coffee work to absorb odors from the air in vehicles.
Dale
Dave64SS
Loc: Cypress, TX
Reg: 02-28-09
06-18-12 02:32 PM - Post#2238825
In response to 64 impala ss
get a big box of baking soda...dump that all over the carpet...wait a day or so..vacuum
64ss409
Reg: 12-04-02
06-18-12 07:03 PM - Post#2238926
In response to Dave64SS
There could still be coolant in the heater housing under the core. When you replace the core, wash the housing with soap and water. Antifreeze does not evaporate like water.
Ron
1964 SS 409/340 4 spd, bought new Oct '63
1964 Biscayne-will have 409
1962 SS convertible 4 spd 327
1971 K10 454
99 Silverado Z11
1998 C5 convertible, torch red black top |
junky
Reg: 06-27-10
06-19-12 05:22 AM - Post#2239026
In response to 64ss409
anti freeze doesn't evaporate, only the water in the anti freeze. If it has been a long while, the water is gone, leaving only the concentrated anti freeeze behind.
frankthetank
Reg: 02-22-11
06-19-12 10:19 AM - Post#2239129
In response to junky
Thanks all. I got a bunch of charcoal and stuffed it in a bag and set it on the floor boards. Planning on shampooing the carpet or maybe febreezing the life out of it than taking it on a long cruise down the hwy with all the windows down after. Hope it helps. Smell has somewhat disappeared since rolling down windows and spraying febreeze in there.
frankthetank
Reg: 02-22-11
06-19-12 12:45 PM - Post#2239167
Ps those charcoal briquettes work wonders, not a smell at all in the car today, thanks fellas.
