tarps (7)
Username Post: Using a TH350c without wiring the lock-up        (Topic#282582)
350cortina
Loc: Durban,South Africa
Reg: 06-13-12
06-14-12 06:10 AM - Post#2237010
Hi people! Can anyone let me know what the side effects of running the TH350c without hooking up the lock up wiring?
'Natural ability without education has more often raised a man to glory & virtue than education without natural ability'
Allan In NE
Reg: 12-27-11
06-14-12 06:21 AM - Post#2237013
    In response to 350cortina
Side effects?
None really, other than the 8% loss in fuel effeciency.
Allan
Lifelong GM automatic transmission specialist
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
06-14-12 06:49 AM - Post#2237018
I run non-lockup on my th350. Can't comment on mileage since it's always been like this, but it's not great. Probably will go with a lock-up convertor next time, though.
Bill - 55 Chevy 210 2 Door Sedan
http://s18.photobucket.com/albums/b129/bluedevil fx...
Tearin' it up:
http://www.youtube.com/watch?v=Xth2oTXLk1Q&a mp;fea...
350cortina
Reg: 06-13-12
06-14-12 08:12 AM - Post#2237045
    In response to Allan In NE
Thanks for the input.
350cortina
Reg: 06-13-12
06-14-12 08:18 AM - Post#2237049
Is the TH350c & TH200-4R torque converters the same? Cos the input shaft looks alike but i dont see any plug for the lock-up on the gearbox housing.
motorman
Loc: south western pa.
Reg: 01-25-00
06-14-12 12:32 PM - Post#2237132
there is a lot of slippage when using a lockup converter in the non lock up condition which could heat up the fluid under certain conditions
retired race engine builder,former NASCAR tech inspector. new corvettes owned 1959,1962,1963,1964,1965, 1966,1997,1999,2002,2005, 2008 plus 30+ other chevy cars and trucks along the way
Edited by motorman on 06-14-12 12:33 PM. Reason for edit: No reason given.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
06-14-12 07:50 PM - Post#2237258
around town it will be o.k. on a long road trip it may overheat due to converter slippage.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
Allan In NE
Reg: 12-27-11
06-15-12 06:07 AM - Post#2237354
    In response to 62chevy427
Sir,
This is 100% non-personal towards you in any way shape or form.
But, can't help but wonder who dreams up these silly stories, anyway? This idea is pure, prime #1, USDA inspected bunk.
Allan
motorman
Reg: 01-25-00
06-15-12 06:51 AM - Post#2237363
  • Allan In NE Said:
Sir,
Allan
i got a letter from GM when i bought my 88 silverado never to tow in OD because the converter would be unlocked all the time and cause overheating. they even sent a lock in type dip stick and a extension for the trans vent so it pointed away from the cat convertor. the RPM difference at 65 MPH is about 600 RPMs in verses out of lockup
models916
Loc: Addison, IL
Reg: 05-28-10
06-15-12 10:45 AM - Post#2237433
    In response to motorman
The 350 is NOT an OD transmission. In drive it will not overheat locked or NOT. It will be running 1-1.
Allan In NE
Reg: 12-27-11
06-15-12 11:34 AM - Post#2237453
  • motorman Said:
  • Allan In NE Said:
Sir,
Allan
Yes Sir,
I know all about the vent and dipstick recalls. Worked for GM the better part of a lifetime and installed a couple trainloads of the goofy things.
Yes, you NEVER tow in OD; I've seen those converters get so hot that they turned blue.....and the smell. You cannot describe that gastly odor; ya absolutely gag.
All said and done tho, this man is asking about a 350C transmission, which is nothing more than a run of the mill 350 but equipped with a clutch.
Doesn't hurt 'em a bit to run without the lockup. Just look at the millions upon millions of the hydramatics up thru the 350/400/325s that didn't have a lockup. None heated due to converter slip; it was how they were designed.
You're talking apples and oranges, Pard.
Allan
350cortina
Reg: 06-13-12
06-16-12 05:15 AM - Post#2237742
Great info & truly makes alot of sense,u have put my mind at ease,was a bit worried about it not running full oil pressure without engaging the lock up...Thanks Allen
350cortina
Reg: 06-13-12
06-16-12 05:19 AM - Post#2237743
Would running the stock converter with a cam that calls for 3000rpm stall damage the tranny or stock converter in anyway. Or does it jus effect the way the car pulls from the line?
Execution time: 0.089 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:41 AM
