Username Post: 58 blub chart        (Topic#282502)
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-12-12 04:17 PM - Post#2236353
does anyone have a bulb chart for bulb numbers maybe a cross over to advance auto for a 58 biscayne
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
62sedan
62sedan
Loc: North Dallas area
Reg: 08-12-02
06-12-12 04:40 PM - Post#2236366
    In response to lilrobo
Do you have the vehicle's OWNERS MANUAL? They are listed inside it.
Chuck
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-12-12 05:27 PM - Post#2236388
    In response to 62sedan
I have a service manual on the way ,, thats all
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
bowtieollie
bowtieollie
Reg: 12-06-99
06-12-12 05:43 PM - Post#2236397
Hello Lil Robo,
What bulb are you trying to cross reference??
The bulbs in the '58 are all current production numbers - so I would like to know the "cross over" item??????
Bowtieollie
Chevytalk.com Moderator
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-12-12 06:56 PM - Post#2236417
    In response to bowtieollie
The dash bulbs,,,,, the dome bulb
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
prgm_mgr
Reg: 07-06-05
06-13-12 09:52 AM - Post#2236650
There's a chart at the link below that should be helpful
Mark
http://chevy.oldcarmanualproject.com/chevyresto/58...
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-13-12 10:21 AM - Post#2236663
    In response to prgm_mgr
Well i got the dash lights sorted,, now when i put the dome blub in it blows a fuse?,, i read somewere that there could be trouble in that socket?.
Anyone got any ideas
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
YeniPenny
YeniPenny
Loc: Biloxi, Ms
Reg: 11-26-01
06-13-12 11:02 AM - Post#2236688
A common problem in that circuit is a shorted cigarette lighter.
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-13-12 02:15 PM - Post#2236749
    In response to YeniPenny
only happens when there is a bulb in the dome light ,and the door is open,, i can put a fuse in and keep the door button pushed and its ok let it off and it blows not a instant blow but a slow blow,, you know what i mean ??
thanks
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-13-12 02:41 PM - Post#2236760
i guess when the door is open the switch makes contact and send power to the dome???? and it uses the ground of housing for blub ???? and maybe thats when i get my short ,,, seems funny cause there is no blub in the socket everything is ok so something to do with blub maybe a hort in the socket ,, i need to remove the dome light to see behind it
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
bowtieollie
bowtieollie
Reg: 12-06-99
06-13-12 04:29 PM - Post#2236798
Are you sure you have the correct bulb?
What number are you using???
Wrong lamp - one with one contact can cause this issue as well.
Bowtieollie
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-13-12 04:35 PM - Post#2236801
I think its a 57 best i can tell ,,i will take out the dome light and checkit out,, if i can get it out lol
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
Jens
Jens
Loc: Emerson IA.
Reg: 04-21-02
06-13-12 06:27 PM - Post#2236859
Use 1004 for the dome light. It's the one with the double pins on the bottom as Ollie mentioned. Use T1895 in the dash lights. Same wattage as the TS57 originals but with a heavier duty filiment.
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-13-12 06:42 PM - Post#2236866
    In response to Jens
Looks like i got a t57 for dome and a t53 for dash i havent used the t53 yet,,, i got these from car quest
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-13-12 06:45 PM - Post#2236868
So would the wrong blub cause it to blow the fuse ?...
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
Chair City
Loc: Thomasville, NC USA
Reg: 01-24-04
06-13-12 06:54 PM - Post#2236874
Yes, a bulb with a single base pin will short the two contacts in the socket resulting in a short circuit when the door switch closes.
1960 Impala Spt. Cpe. Daily Driver
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-13-12 07:01 PM - Post#2236878
    In response to Chair City
I will go out and get a 1004 for the dome ,, again thanks for the info,, i cant wait till get theclock working,, i love the clock and when i looked at it there wasnt any wires going to it ,,
Thanks for the info
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-14-12 09:22 AM - Post#2237070
the 1004 fixed the dome light everything works great door open and closed thanks for the info
now to the clock lol
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-14-12 03:23 PM - Post#2237174
found a wire hanging down looks like a dash light it comes on when they do ,,, it much go to glove dept or maybe heater switch light ,, the wiring diag show a heater light , but i didnt see one on mine,, i am trying to find out were it goes, hard to say
anyone got any ideas
thanks
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-15-12 03:20 AM - Post#2237313
Can someone post a pic of aglove dept light,,and a heater light
The service manual shows both,,, but hard to see were the are
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
Jens
Jens
Loc: Emerson IA.
Reg: 04-21-02
06-15-12 04:14 AM - Post#2237319
The glove box lite should have an orange wire going to it. The 58 heater has a gray wire w/plug in bulb that goes at the top of the control unit in the back.
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-15-12 09:04 AM - Post#2237403
    In response to Jens
great thanks , thats what mine is ,, cause if it was the glove box it would not be gray and come on when inst lights come on ,,,, great thanks again ,,easy fix there now i need to find the wire that goes to the glove box i show orange wire ,, i do have a push button on the inside so i will start from there
thanks
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-15-12 09:39 AM - Post#2237407
got it fixed works great ,, i do see a switch for the glove dept with a orange wire time to trace back ,, the only thing i dont see a spot for a blub ,, maybe when the box was changed they didnt cut the hole for the blub
thanks
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
prgm_mgr
Reg: 07-06-05
06-15-12 11:27 AM - Post#2237450
I found a wiring diagram for sale online for around $15.00. It measures 11x14 and is laminated. I think he also had an 8x10 but the price difference wasn't that much.
I found it very useful in tracing circuits - easier than the B&W in the shop manual.
Just a thought
Mark
I check on ebay - price went up to $20.00 - still easier on the eyes!
Link below:
http://www.ebay.com/itm/1958-58-Chevy-Imp ala-Lamin...
Edited by prgm_mgr on 06-15-12 11:36 AM. Reason for edit: No reason given.
prgm_mgr
Reg: 07-06-05
06-15-12 11:31 AM - Post#2237452
The socket for the glove compartment is at the end of the push button switch. The wire has a connection in the shape of a "J" - like a hook. The hole in the glovebox is about 1/4" in diameter and is located slightly behind the switch -on the left side of the box as you look in the box.
If I recall correctly, there is a picture of this in the Assembly Manual.
Mark
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-15-12 01:58 PM - Post#2237502
all i have is shop manual is the Assembly Manual a big need ??
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
prgm_mgr
Reg: 07-06-05
06-15-12 02:08 PM - Post#2237508
It depends on how much you're going to be doing.
If all you need to do is replace bulbs then not really. If you find yourself getting deeper and deeper then in my opinion, a big help, especially if looking at line drawing help you figure things out.
To me both are essential along with the Accessory manual since some things are not it the Shop Manual or the Assembly Manual. In short, if I wee to get another car of a different year or make, I'd try to locate all three books - of course alot depends on you experience with cars and your finances.
Just my two cents!
Mark
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-15-12 02:54 PM - Post#2237530
ok i dont know how deep i need to most everything is done ,,i was trying to get these few odd and ends done , all i have is the glove box light and i would like to see if the clock will work,, i hooked up a hot wire to the clock and i got a little spark so i thought it would work ,, i even check for continuity and got it,, so it might not work , even so the glove box will i would say that the box was change with after market and there is no hole ,, i will look ,, thanks for all the help , this place is great
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
Jens
Jens
Loc: Emerson IA.
Reg: 04-21-02
06-15-12 05:33 PM - Post#2237592
58 glove box showing hole for wire & light.
lilrobo
lilrobo
Loc: lexington ky
Reg: 06-03-12
06-15-12 05:45 PM - Post#2237600
    In response to Jens
Sweet you guys are the best , i may be just missing a blub
Back to the car
Thanks again
1958 Chevy Biscayne
235 6 cyl
2 speed P/G tranny
Execution time: 0.086 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:42 AM
