tikiwagon
Loc: dorset, england
Reg: 04-23-04
06-12-12 02:07 PM - Post#2236296
I have a full CPP disc brake conversion with dual master and servo which i fitted to my 59 last year but it still suffers from a very low brake pedal(it is firm but almost at full travel)I have bled the brakes several times and no air comes out. The whole system is all brand new and i have the servo to master rod adjusted so there is nominal free play, I even took the master apart last week and put a new rebuild kit from you in it as i thought it was that but no difference!Would adjusting the underdash threaded rod help on this(i also redrilled the the pedal to the lower position as per your instructions)It has drove me mad and several knowledgable mechanics looked as well,Any advice please as i have a long road trip next week and want to make sure the brakes are spot on
cpptech
Loc: CA. USA
Reg: 12-08-06
06-12-12 02:43 PM - Post#2236313
In response to tikiwagon
rear emergency brake adjustment. follow the adjustment procedure on the website.
Thanks,
Aaron @ Classic Performance
800-522-5004 |
tikiwagon
Reg: 04-23-04
06-13-12 04:05 AM - Post#2236505
In response to cpptech
Thanks, where is that(Can you post a link)Also how will this affect my pedal though?
tikiwagon
Reg: 04-23-04
06-13-12 01:59 PM - Post#2236740
It has the stock drum rear which i may have misled you on!
tikiwagon
Reg: 04-23-04
06-18-12 12:53 PM - Post#2238785
When rebleeding the brakes i notice the master is actually moving forward fractionally with the front section of the booster,The bracket is secured to the firewall, what is happening with this?
cpptech
Loc: CA. USA
Reg: 12-08-06
06-20-12 07:24 AM - Post#2239418
only thing that could give would be the firewall if its a little fatiqued. Also, make sure you drilled the lower hole in the pedal so the ratio is correct. The 3/8" hole needs to be 1" lower then the factory upper hole.
Thanks,
800-522-5004 |
tikiwagon
Reg: 04-23-04
06-20-12 12:50 PM - Post#2239497
its not the firewall moving its the front part of the booster and the master,I did re drill the pedal 1" lower too
cpptech
Loc: CA. USA
Reg: 12-08-06
06-21-12 07:49 AM - Post#2239768
how did pinching off all front and rear hoses work? Did the pedal stay high?
Thanks,
800-522-5004 |
tikiwagon
Reg: 04-23-04
07-01-12 09:02 AM - Post#2243289
I will try this but why is the master moving though?
cpptech
Loc: CA. USA
Reg: 12-08-06
07-02-12 08:15 AM - Post#2243601
only thing I can think is there is a bind somewere like the rod is trying to puch at an angle or something.
Thanks,
800-522-5004 |
