rob983
Loc: Detroit MI
Reg: 09-20-04
06-09-12 09:50 AM - Post#2235120
Would anyone know the diameter (or specs) of the coil for a 1964 Impala SS front spring?
Not sure what springs are on the car but I would like to return it to the original ride height.
It's sits too high now.
junky
Reg: 06-27-10
06-09-12 07:56 PM - Post#2235290
In response to rob983
The diameter of the springs are all the same. It is the wire dimension that changes, and the number of turn that determines the ride hight. I would do a check of the ride hight per the instructions in the FSM to determine if it is too high before doing anything. Today, getting the correct springs can be difficult, but there is one company that still makes springs using the original GM drawings. Not cheap, but you get what you pay for.
hsfdchief200
Loc: Shreveport, LA
Reg: 04-21-12
06-09-12 09:15 PM - Post#2235315
In response to junky
Not to hijack the thread, but who is that company? I'll be replacing mine soon.
| 1963 Biscayne 4 door, 230, 3 speed column shift |
62sedan
Loc: North Dallas area
Reg: 08-12-02
06-10-12 04:09 AM - Post#2235351
In response to hsfdchief200
Try here....... http://www.eatonsprings.com/
rob983
Loc: Detroit MI
Reg: 09-20-04
06-12-12 02:01 PM - Post#2236292
The diameter of the wire is what im looking for.
Eaton Springs (Detroit Spring) is 2 miles from me, Its the first place I checked, I was told that there is no way to tell.
on Eaton Springs Website it explains that spring application is determined by; length of spring, number of coils, diameter of wire.
hsfdchief200
Loc: Shreveport, LA
Reg: 04-21-12
06-12-12 09:17 PM - Post#2236461
I can't say about 1964, but I know in 1963 the wire diameter of the springs were NOT the same among all the applications. This is shown in the 1963 Passenger Car Specifications publication.
I emailed the Spring Guru at Eaton and listed all the detailed GM specs from that publication for my particular application. He responded and said that that wire diameter is no longer available. He gave a part number for the front and rear, but it appears to be just like all of the other springs in all the parts catalogs - it's a generic part number that covers many applications, both 6 cylinder and V8. After finding this out, I'm not so sure I can justify the doubled price of Eaton springs since it appears that the springs are not built to actual GM specs as they claim.
Edited by hsfdchief200 on 06-12-12 09:18 PM. Reason for edit: No reason given.
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
06-13-12 06:11 AM - Post#2236538
Here is what I found out:
Sure.
MOG-6000 .656" diameter, 305 lbs/in spring rate, 18.6" free height, installed height 11.8"
MOG-6004 .671" diameter, 325 lbs/in spring rate, 18.8" free height, installed height 11.8"
MOG-6084 .671" diameter, 377 lbs/in spring rate, 16.8" free height, installed height 12.0" (this free ht looks funny, but I checked it twice)
MOG-658A .687" diameter, 404 lbs/in spring rate, 18.8" free height, installed height 11.8"
Hope this helps
rob983
Loc: Detroit MI
Reg: 09-20-04
06-13-12 05:31 PM - Post#2236824
In response to turbo38s10
Thanks,
I will measure my springs tomorrow.
My car with current springs.
http://images5a.snapfish.com/232323232%7Ffp635%3A7 ...
Edited by rob983 on 06-13-12 05:35 PM. Reason for edit: No reason given.
rob983
Loc: Detroit MI
Reg: 09-20-04
06-14-12 06:18 PM - Post#2237235
Checked springs today, old ones wire dia. is .718
The new ones measure .656 dia.
Thanks.
Current ride height:
bsa_bob
Reg: 12-07-11
07-08-12 10:34 AM - Post#2245705
Sure.
Hope this helps
Where may i ask did you get these specs???????Iam having trouble with my 07 silverado "lowered springs rides terrible]maybe i can figure out what i need to do with a different set And eaton spring is to expensive for my blood too. Someone here mentioned this any help great+thank you bob s
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
07-08-12 01:47 PM - Post#2245769
In response to bsa_bob
Summit Racing Tec line gave them to me.
cowfarmer350
Reg: 02-03-01
07-08-12 05:12 PM - Post#2245830
If you know your Moog part number punch it in to the search on this website and look at the bottom of the page it will give the specs of the spring , .... http://www.moog-suspension-parts.com/proddetail.as...
Sweed62
Reg: 10-24-04
07-08-12 05:29 PM - Post#2245838
Welcome rob.
Funny, while working on my body, i leveled the body to shop manual frame specifications, then, (2 dr HT Tarrytown) the rocker, is dead on horisontal, and side trim is lower at the rear. I really do like that stance. There is a riding height measure in the shop manual for the front, but not for the rear if i remember right. See if you can find it or ask again. I do like your stance anyway, she looks grat. To high refering to what?
Svenne
Edited by Sweed62 on 07-08-12 05:50 PM. Reason for edit: No reason given.
dcairns
Loc: Orange CA
Reg: 11-07-03
07-08-12 08:19 PM - Post#2245918
In response to Sweed62
What I bought:
Moog
658A front
Inside Diameter 3.810
Bar Diameter 0.687
Install Height 11.81
Load 2052
Spring Rate 404
Free Height 16.89
6033 rear
Inside Diameter 3.670
Bar Diameter 0.656
Install Height 11.00
Load 2005
Spring Rate 370
Free Height 16.44
Tires 245/60/14, somewhat smaller diameter than the stock tire.
Looks like this:
Edited by dcairns on 07-08-12 08:21 PM. Reason for edit: No reason given.
