Username Post: Trans in LIMP Mode...        (Topic#282327)
cfreiling
Reg: 06-09-12
06-09-12 09:35 AM - Post#2235109
I received code P0756, which points to the A & B Solenoids in the transmission. I have tested these and replaced them, however I still have the problem where it seems like it is LIMP mode (Stays in 2nd). It shifts from 1st to 2nd then does not shift again. The only thing that was changed were the two shift solenoids.
Truck is a 1999 Chevy Suburban.
This is the work I've done already.
http://troubleshootmyvehi cle.com/gm_shift_solenoid...
Any help???? Is there something simple I am missing like a fuse or????
DEI8FAN
DEI8FAN
Loc: Western, N. Carolina
Reg: 02-01-05
06-11-12 04:01 AM - Post#2235672
    In response to cfreiling
I have read that a bad ignition switch can cause that, try googleing P0756
And you get more answers in the truck section.
1959 El Camino
1970 El Camino
1981 Corvette
2004 Z71
2005 Monte Carlo
Edited by DEI8FAN on 06-11-12 04:02 AM. Reason for edit: No reason given.
cfreiling
Reg: 06-09-12
06-13-12 07:11 PM - Post#2236884
    In response to DEI8FAN
Thanks, didnt realize I was in the Car section
68 ragtop
Loc: N.C.
Reg: 03-22-09
11-16-12 06:42 AM - Post#2289506
Had an 09' Impala that did the same. Dealership found the throttle body had an inconsistant signal when gas pedal was used. Just a thought.
transexpert
Reg: 01-11-13
01-11-13 01:01 PM - Post#2306229
if it shifts 1-2 then neutrals out the 3-4 clutches are burned out.
very common on these. when computer sees no 3rd it blames solenoid.
Execution time: 0.09 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:56 AM
