Username Post: Rim repair        (Topic#282325)
bluenozr
Loc: Nova Scotia Canada
Reg: 02-27-12
06-09-12 08:52 AM - Post#2235101
I have a 2010 Sierra,2500 HD with 16" alloy/clear coat wheels. There are small spots on the rims that salt/water etc .has got under the clear coat andthe alloy has started to corrode. Anyone have any good tips on repairing these spots or awebsite where I could find this info? Thanks,Steve
Matt
Matt
Loc: SAV
Reg: 09-26-01
06-09-12 04:23 PM - Post#2235229
    In response to bluenozr
Your best way would be to have them refinished. A local tire shop can give you recommendations on who would do it for you.
When I had a Mazda6 a few years ago, it had 17" wheels. The tire shop did a terrible job, ruined the wheels (all 4 of them if you can believe it! rookie tire installer). They sent it to a shop to have it refinished and told me that it cost them $200 to fix all 4 wheels.
junky
Reg: 06-27-10
06-09-12 08:09 PM - Post#2235296
Don't know if Keystone operates in Canada, but if they do, they have an exchange program for allow wheels.
elcamino
elcamino
Reg: 03-30-00
06-10-12 03:19 AM - Post#2235345
    In response to junky
Friend just had the aluminum wheels on his 2011 Silverado HD replaced under warranty for this issue. Truck was less than 1 yr old.
He thought they would refinish them but he was told they do not do that anymore because it can weaken the wheel and become a safety issue, refinishing that is.
2009 Cadillac CTS4 AWD Performance Sedan
2012 GMC Sierra AWD Denali 6.2L
06-10-12 06:27 AM - Post#2235368
    In response to elcamino
That sounds like a pretty crazy claim - refinishing weakening the wheel, but if the end result was your buddy got new wheels, no sense in arguing it.
I'd be looking for warranty relief on it too since the truck is only 2 years old. That seems really, really early for clearcoat failure on the wheels even in a salt environment, unless they're constantly in it and you never clean them off.
BTW, this is wheel refinishing info straight from a 1994 GM truck service manual, not suggesting anyone do it themselves, but it was at least the accepted way "back then":
Vista Cruiser
Vista Cruiser
Loc: Erie Canal
Reg: 10-01-99
06-10-12 11:14 AM - Post#2235449
    In response to someotherguy
It starts with a cut in the clear. Usually wheel weights, but a stone chip, scrubbing a curb, or any kind of deep scratch can do it.
Salt gets on the bare aluminum......... toast.
In the North where road salt is used, oxidation happens quick.
Kenney AKA Blizzardboy
09 Impala SS....82 T/A.........72 Vista Cruiser
12 Cruze....98 Riviera...07 C-1500
68 Firebird
elcamino
elcamino
Reg: 03-30-00
06-10-12 03:55 PM - Post#2235520
fyi
Read the latest. Wheels are a safety item so improper refinishing can leave the dealer and GM liable.
Document ID: 1841203
#99-08-51-007C: Info - Refinishing Aluminum Wheels - (Jun 19, 2006)
http://gsi.xw.gm.com/image_en_us/gif/000/9 99/999/9... Subject:Refinishing Aluminum Wheels
Models:2007 and Prior Passenger Cars and Trucks (Including Saturn)
2003-2007 HUMMER H2
2006-2007 HUMMER H3
2005-2007 Saab 9-7X
This bulletin is being revised to add additional models and model years. Please discard Corporate Bulletin Number 99-08-51-007B (Section 08 - Body and Accessories).
This bulletin updates General Motor's position on refinishing aluminum wheels. GM does not endorse any repairs that involve welding, bending, straightening or re-machining. Only cosmetic refinishing of the wheel's coatings, using recommended procedures, is allowed.
Evaluating Damage
In evaluating damage, it is the GM Dealer's responsibility to inspect the wheel for corrosion, scrapes, gouges, etc. The Dealer must insure that such damage is not deeper than what can be sanded or polished off. The wheel must be inspected for cracks. If cracks are found, discard the wheel. Any wheels with bent rim flanges must not be repaired or refinished. Wheels that have been refinished by an outside company must be returned to the same vehicle. The Dealer must record the wheel ID stamp or the cast date on the wheel in order to assure this requirement. Refer to Refinisher's Responsibility -- Outside Company later in this bulletin.
Aluminum Wheel Refinishing Recommendations
• Chrome-plated aluminum wheels
Re-plating these wheels is not recommended.
• Polished aluminum wheels
These wheels have a polyester or acrylic clearcoat on them. If the clearcoat is damaged, refinishing is possible. However, the required refinishing process cannot be performed in the dealer environment. Refer to Refinisher's Responsibility -- Outside Company later in this bulletin.
• Painted aluminum wheels
These wheels are painted using a primer, color coat, and clearcoat procedure. If the paint is damaged, refinishing is possible. As with polished wheels, all original coatings must be removed first. Media blasting is recommended. Refer to GM Aluminum Refinishing Bulletin #53-17-03A for the re-painting of this type of wheel.
• Bright, machined aluminum wheels
These wheels have a polyester or acrylic clearcoat on them. In some cases, the recessed "pocket" areas of the wheel may be painted. Surface refinishing is possible. The wheel must be totally stripped by media blasting or other suitable means. The wheel should be resurfaced by using a sanding process rather than a machining process. This allows the least amount of material to be removed.
Important: Do not use any re-machining process that removes aluminum. This could affect the dimensions and function of the wheel.
Painting is an option to re-clearcoating polished and bright machined aluminum wheels. Paint will better mask any surface imperfections and is somewhat more durable than clearcoat alone. GM recommends using Corsican SILVER WAEQ9283 for a fine "aluminum-like" look or Sparkle SILVER WA9967 for a very bright look. As an option, the body color may also be used. When using any of the painting options, it is recommended that all four wheels be refinished in order to maintain color uniformity. Refer to GM Aluminum Refinishing Bulletin #53-17-03A for specific procedures and product recommendations.
Important: Some outside companies are offering wheel refinishing services. One such company, Transwheel Corporation (800-892-3733), provides this service within GM guidelines. Other companies may also exist. Such refinished wheels will be permanently marked by the refinisher and are warranted by the refinisher. Any process that re-machines or otherwise re-manufactures the wheel should not be used.
A refinisher's responsibility includes inspecting for cracks using the Zyglo system or the equivalent. Any cracked wheels must not be refinished. No welding, hammering or reforming of any kind is allowed. The wheel ID must be recorded and follow the wheel throughout the process in order to assure that the same wheel is returned. A plastic media blast may be used for clean up of the wheel. Hand and/or lathe sanding of the machined surface and the wheel window is allowed. Material removal, though, must be kept to a minimum. Re-machining of the wheel is not allowed. Paint and/or clear coat must not be present on the following surfaces: the nut chamfers, the wheel mounting surfaces and the wheel pilot hole. The refinisher must permanently ID stamp the wheel and warrant the painted/clearcoated surfaces for a minimum of one year or the remainder of the new vehicle warranty, whichever is longer.
Important: Whenever a wheel is refinished, the mounting surface and the wheel nut contact surfaces must not be painted or clearcoated. Coating these surfaces could affect the wheel nut torque.
When re-mounting a tire on an aluminum wheel, coated balance weights must be used in order to reduce the chance of future cosmetic damage.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
http://gsi.xw.gm.com/image_en_us/gif/000/9 99/999/9... WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
06-10-12 04:25 PM - Post#2235536
From what I see they're 100% OK with the alloy wheels being refinished, they just don't want the liability of doing it in-house.
bluenozr
Reg: 02-27-12
06-11-12 05:02 AM - Post#2235685
Thanks for the input, I think that I will go the Dealer/warranty route.Be interesting to see how that goes........., Steve
Execution time: 0.103 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:51 PM
