Username Post: 427 white smoke new engine        (Topic#282110)
katreg
Reg: 06-04-12
06-04-12 02:13 PM - Post#2233387
just rebuilt a tall deck 427 , started up ran fine until I started to add water then had extreme amounts of white smoke from both exhaust pipes. Everything in the engine is new but obviously something is wrong . any ideas thanks. did compression test tested good only odd ball is I used standard deck manifold with spacers.
bobschevytrucks.com
JimKshortstep4x4
Chevytalk Moderator & "9th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
06-04-12 05:53 PM - Post#2233476
    In response to katreg
Welcome to Chevy Talk from West Michigan!
My suggestion would be to pressurize the cooling system to 10 psi, pull the spark plugs and rotate the engine with the plugs out. The cylinder(s) with water in them will spray water out when turning the engine over. This may help you track the leak down. Good luck!
Member 65-66 Full Size Chevrolet Club
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
71 Short bed stepside 4x4, 350/350
Current project, 72 GMC Shortbed, stepside, 427
bullmecha
Reg: 07-25-12
07-25-12 01:51 PM - Post#2252096
I agree with Jim, check for coolant leaks.
May have a head gasket leaking into the cylinders. Had that problem on my lil gas saver Toyota. Tons of white smoke and no power goin down the road.
1972 Custom Deluxe Long Bed
350 (unknown bore)
700r4 tranny (OD for mileage)
Edelbrock 1406 Carb
Edelbrock Intake
evot123
Loc: s.c.
Reg: 02-11-09
08-01-12 02:23 AM - Post#2254398
ive never seen the spacers work. they leak water into the intake runners. to fix it right count on buying the right manifold but i have seen one work with a lot of silicone used on both sides.....mike
dont give up, help is on the way
bobschevytrucks.com
Execution time: 0.099 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:56 AM
