tarps (7)
Username Post: roller tip fuel pump rod        (Topic#281979)
johnod
Loc: Southern Ontario
Reg: 05-27-12
06-01-12 07:48 PM - Post#2232398
Today I'm putting the engine back together. One of the things I wanted to add was the above mentioned fuel pump rod. This has a "bolt" which goes thru the threaded hole in the front of the block to keep the rod from rotating.
Simple right?
But.. the damn hole is blind, did Chevy change that sometime?
When?
Is there a fix i can do?
motorman
Loc: south western pa.
Reg: 01-25-00
06-02-12 09:13 AM - Post#2232520
    In response to johnod
Simple right?
When?
with that roller tip fuel pump rod you should to be running a steel billet roller cam to prevent cam wear
retired race engine builder,former NASCAR tech inspector. new corvettes owned 1959,1962,1963,1964,1965, 1966,1997,1999,2002,2005, 2008 plus 30+ other chevy cars and trucks along the way
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-02-12 10:05 AM - Post#2232535
    In response to motorman
this may help
motorman
Reg: 01-25-00
06-02-12 07:20 PM - Post#2232712
    In response to grumpyvette
  • grumpyvette Said:
we used them on high pressure,high volume alky fuel pumps to prevent the cam fuel pump eccentric wear. electric pumps solve this problem but some places you are not allowed a electric fuel pump.
Edited by motorman on 06-02-12 07:21 PM. Reason for edit: No reason given.
johnod
Reg: 05-27-12
06-03-12 12:49 PM - Post#2232954
I am running an erson roller cam.
I read some where the roller tip pushrod was a good thing so you dont wear of the eccentric on the cam,( a friend has developed this problem).
So I thought I'd avoid the cam wear with the pushrod. But as i said the hole thru the block is blind. Next time the motor is out, I'll drill and tap it. If I can avoid electric pump i will,don't care for the added noise. It is after all a street car and i like to travel long distances with it.
Thanks for all the input.
Execution time: 0.096 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:31 AM
